Leaf spring TSB for 2013 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VTacoma2013, May 15, 2013.
  1. May 16, 2014 at 1:29 PM
    #181
    bueller
    bueller Well-Known Member
    AZ
    This thread pretty much covers everything about the newest TSB for driveline vibrations on the Tacoma. Verify with your dealer if in fact it is TSB-0008-14 that they are doing.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/254438-driveline-vibration-tsb-out.html
  2. May 16, 2014 at 4:27 PM
    #182
    JDeLuca
    JDeLuca Well-Known Member
    Joe
    Staten Island NY
    2013 TRD Sport MGM
    TRD Cat Back Exhaust, Bed mat, Weather Techs wet okole seat covers
    My 2013 Sport has the 4 leaf pack also.
  3. Aug 26, 2014 at 5:02 PM
    #183
    Johnny99
    Johnny99 Member
    Tampa, FL
    98 Tacoma 2.4- 4cyl. auto
    topper
    I just looked under the back of a 2013 4 WD 2.7L at the Toyota lot and it had the 2+1 leaf springs on it. So should that be changed? I'm debating on buying it if it's around in 2 weeks. I also saw the driveline vibration TSB in the other thread but the 4WD 2.7 wasn't listed on it either. I haven't test driven this one yet so don't know if that is an issue.
  4. Aug 30, 2014 at 7:05 AM
    #184
    Parrothead1809
    Parrothead1809 Well-Known Member
    I'm working with the local Toyota shop to apply this TSB to my 2010 TRD Double cab. I stared doing some light hauling and hope this will stiffen up the ride.
    The other issue I hope it resolves is the loud bang when I go over deep pot holes or RR tracks, that I hear from the back. These are true whether I'm hauling or not. Any thoughts?
    Also, does this TSB give any lift to the truck? And finally, has anyone who has had this done, regretted it afterwards?
    Thanks as always - this is the best Taco board on the web!!!!!
    -PH
  5. Aug 30, 2014 at 3:20 PM
    #185
    tacomavol87
    tacomavol87 Member
    Caleb
    Tennessee
    05 Speedway Blue Base TRD Off-Road
    Does anyone know if this TSB applies to 05 model Taco's????
  6. Aug 30, 2014 at 3:23 PM
    #186
    mshultz
    mshultz Well-Known Member
    Michael
    Wooster, Ohio
    Barcelona Red
    Mine has the 2+1 springs and rides fine. I probably have not had more than a couple of hundred pounds in the bed, though.
    If you pay attention, there is a little bit of driveline vibration when you accelerate from a stop, but it is minor. The regular cab does not have a 2 piece driveshaft.
  7. Aug 30, 2014 at 6:15 PM
    #187
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    it does lift slightly. I did it on my 2009 and thought the ride was much improved but I prefer a firmer ride.
  8. Sep 8, 2014 at 9:22 PM
    #188
    Thergood
    Thergood Active Member
    Pennsylvania
    2015 Access Cab TRD Off Road
    Does anyone know if this still a problem for the newest '14s and '15s? I've got a '15 TRD OR on the way.
  9. Sep 18, 2014 at 3:04 AM
    #189
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
    My '13 DCSB 4x4 TRD OR has the 3-leaf pack. 28k miles, so under warranty. Dealer wouldn't do rear leaf TSB. The 2014 and '15s at the dealer had the 4-leaf pack though.
    I wonder what the difference is between the 2013 3-leaf pack and those that do qualify for the TSB....
    My back sits 36 1/4" from ground to fender, just under 2" higher than the front which sits 34 3/8". So, my plan to level with Eibachs & 5100s at 0" should pretty much work out great anyways.
    Now if I could just decide between 265/70 or 75 BFG All-Terrains....:confused:
  10. Sep 18, 2014 at 8:45 AM
    #190
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    just get the TSB done for the driveline vibration. according to the tsb the trd or's get the 3+1 leaf pack.
  11. Sep 20, 2014 at 9:25 AM
    #191
    Thergood
    Pennsylvania
    Just picked up my 2015 AC OR. It has the 3+overload pack. There is some slight driveline vib when accelerating very hard in a straight line from 0-10mph, nothing major. I probably wouldn't have even noticed it if I hadn't been reading this and the other threads on here.
  12. Nov 2, 2014 at 10:11 AM
    #192
    Parrothead1809
    I'm in the queue for this TSB too. Dealer says they are still waiting for Toyota to determine all the parts and repair procedures for all the models effected.
    Question: Are the rear shocks also replaced as part of a repair like this? Should I consider have bing them replaced too, even if they are not part of the TSB?
    Thanks,
    -PH
  13. Mar 28, 2015 at 8:23 PM
    #193
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    going to call my service manager this coming monday
    Im for sure having these two problems (driveline vibration and the rear clunk noise from the rear propeller shaft). Although the second tsb looks like its for 05-12 only, mine is 2013. But I have the rear clunk noise for sure. Ive always wondered what that was. We'll see what the dealership says. But my service tech is pretty cool so we shall see. Ill keep you all updated.
  14. Jun 1, 2016 at 3:35 PM
    #194
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Curious if any 2014 owners noticing any frowning leafs?
    Mine are not quite flat anymore just barely frowning. I have never towed or hauled anything.
  15. Jan 19, 2017 at 7:24 AM
    #195
    Easchar0
    Easchar0 Active Member
    Ed
    2015 tacoma trd offroad pyrite mica
    My 2015 OR with 20k have 3+1 and they are upside down as well going to try and get a new set under warranty and then add airbags
  16. May 25, 2017 at 12:37 AM
    #196
    Johnkkaw
    Johnkkaw Active Member
    13 Tacoma off road
    3 inch lift roof racks smittybilt awning. Yakima ski clamps led headlights and fog lights. Led reverse lights and rigid aux reverse lights. Smittybilt built 95k winch and rigid 30 inch bar in grille. Alpine type r sub in spec box behind rear seat. Power pack amp pass through wire to factory deck
    Have a 2013 dblcab short bed and the rear leaf Springs are actually arched backwards. don't take much weight and it bottoms out while driving and hitting bumps
  17. Feb 3, 2018 at 9:32 AM
    #197
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I know this an old thread but I feel the need to add my two cents.
    First off the Tacoma is partially designed for off-road and that being said... less springs are better. If used for hauling or towing than more springs are better. Its impossible to make a truck that pleases everyone.
    Second: Payload is what you put in the bed of your truck and the Tacoma is rated for 1200 lbs at least. That makes it a 1/2 ton truck. It’s ok for there to be different size half ton trucks. The only 1/4 ton I ever heard of was a small Jeep type thing we had in the army. My ‘91 pickup was rated for 1200 lbs and I would carry a ton on it without it bottoming out.
    I put 600 lbs tongue load on my ‘13 regularly and it drops about 2”. It has 4 leafs.
