leaf spring tsb?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paintdiddy, Oct 17, 2009.
  1. Oct 17, 2009 at 7:25 AM
    paintdiddy
    paintdiddy [OP] Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i did a search and couldnt find it. how do i know if i need it done.i have a cap and my truck is always loaded with tools.just had my front wheels aligned and they said cuz of the soft rear leafs, the caster/camber (forgot which one he said) would be off and thats why my front tires are already wasted at 25k miles.my truck sags alittle i guess. tires screech around turns and my alignment wasnt really off either. oh i have an 08 d/c l/b 4X4
  2. Oct 17, 2009 at 7:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check the bumpstops and see if they have been hitting the frame.
  3. Oct 17, 2009 at 7:31 AM
    paintdiddy
    shithead
    silver bullet
    ok thanks if they dont...i dont need it done??
  4. Oct 17, 2009 at 7:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your not bottoming out, then you really dont need it. You could get by with an AAL. BUT, it probably couldnt hurt to talk to the dealer about it.
  5. Oct 17, 2009 at 7:33 AM
    paintdiddy
    shithead
    silver bullet
    ok ill check my junk out and be back in a bit.
    i thought they were markings on the leafs or number in leaf pack that let you know if u need it
  6. Oct 17, 2009 at 7:39 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    The best thing I've ever done to my truck was the rear spring TSB. I'd say with a cap and tools it'd be a MUST. I highly recommend it! It will cost you nothing and it rides much better even with an empty bed.
  7. Oct 17, 2009 at 8:03 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Some people have not had any problems with their trucks to want/need it done.
    When mine is loaded, I was hitting the bump stops - I have the wear marks to prove it.
  8. Oct 17, 2009 at 8:11 AM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
  9. Oct 17, 2009 at 8:14 AM
    ImpulseRed008
    Susan
    SC
    There are part numbers on the springs that will let you know if you are ELIGIBLE for the tsb - not that you HAVE to get it done.
