Leaf springs are squeaking
Discussion in 'Suspension' started by jz23, Jul 9, 2015.
  1. Jul 9, 2015 at 9:30 AM
    jz23
    jz23 [OP] Well-Known Member
    jon
    madison wisconsin
    2009 tacomaregular cab 2x4
    none
    I have a 2009 4x4 regular cab and my fricken leaf springs are squeaking like crazy. All I have to do is push on the truck with my hand and it squeaks. My question is, does anyone know if I should replace the leaf, the shackles or both. I can't seem to pin point where the noise is coming from and I don't want to waste money if it's not needed.
    Has anyone else experienced this issue and how did you remedy it?
  2. Jul 9, 2015 at 10:29 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    My Double Cab does the same.
    I spray PB blaster on the leaf springs, and it quiets down for a bit.
