Leaf Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vanzigler, Aug 21, 2011.
  1. Aug 21, 2011 at 5:02 PM
    vanzigler
    vanzigler [OP] Active Member
    Van
    alberta
    05 tacoma v6 sr5 TRD sport
    aFe Cold Air Intake si with 5R filter, Flowmaster Dual Exhaust, OME 885 Dakar suspension kit, Hella Driving lights, VVME 35W HID headlights, VVME 55W HID Fog lights, 2" BORA Wheel Spacers, Throttle Body Spacer
    Hi guys my 2005 Tacoma's rear end is sagging, my local dealership told me that there is a TSB #3055 on it. MY question is do I have to change the front as well? Thanks!
  2. Aug 21, 2011 at 5:04 PM
    jandrews
    '09 FourDubDee TRD OR
    The front what?
  3. Aug 21, 2011 at 5:10 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Two threads ?
  4. Aug 21, 2011 at 5:12 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not sure if TSB's apply to Canadian trucks... If you're asking about replacing the front coilover suspension then the answer is no. I do not believe there is an issue with them sagging.
  5. Aug 21, 2011 at 5:28 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    It doesnt change the front suspension, however, if the dealer is willing to do it and give you a new setup, why wouldnt you?
  6. Aug 21, 2011 at 8:02 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Search friend, there is a gazillion and a half posts about the rear spring tsb. And no it doesn't have anything to do with the fronts.
  7. Aug 21, 2011 at 8:06 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i think he is referring to the fact that the swap out the shocks for the trd billies IIRC with the leaf spring tsb
  8. Aug 21, 2011 at 11:06 PM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    Suscribe my 05 leaf pack sucks. Had some camping gear in the bed and almost riding on bump stop.
  9. Aug 21, 2011 at 11:07 PM
    OZ-T
    Peter North
    British Columbia
    The TSB only applies if you still have warranty
  10. Aug 21, 2011 at 11:52 PM
    vanzigler
    Van
    alberta
    I was talking to a guy who works at a local 4x4 shop here and he said that if he was gonna do it then he'll upgrade the front and the back! He said that if the front is left stock and the rear upgraded then the truck would look funny and it wouldn't be safe! What do you guys think about that?
  11. Aug 21, 2011 at 11:54 PM
    OZ-T
    Peter North
    British Columbia
    The TSB springs will only raise the rear 1" , you can only get the TSB done if you still have warranty
    As for being unsafe , all 2007 - present Canadian 6 lug Tacomas come stock with the 4 leaf " TSB " pack
  12. Aug 22, 2011 at 12:07 AM
    vanzigler
    Van
    alberta
    I was thinking of replacing my rear leaf springs and shocks with OME. The OME's should raise the back by 2"-2.5" right? Is that a good choice or what do you think? Will it look funny then? Thanks!
  13. Aug 22, 2011 at 12:15 AM
    acdronin
    acdronin Well-Known Member
    The rear leafs on these truck suck, period, if the dealer is willing to do it, then by all means get it done, OME's are a good choice too, but there are other routes you can take, look into add a leafs, airbags and what is very popular here is the Bilstein 5100 shocks. I have two inch add a leafs, billie 5100 shocks and Firestone riderite airbags, i put 5100's in the front adjusted to 1.75 inches and with the airbags i can make the truck perfectly level. Pump these terms into the search function and you will find lots a lots of info on this.
  14. Aug 22, 2011 at 7:23 AM
    OZ-T
    Peter North
    British Columbia
    The OME Dakar leaf pack will raise the rear 2 3/4 - 3 " on a DC .
    In that case you probably should lift the front as well .
    If you aren't going to lift the front , look at getting an AAL or just the TSB springs you apparently qualify for , then add an AAL .
