Leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by blt2tuk, Jun 11, 2015.
  1. Jun 11, 2015 at 10:04 AM
    blt2tuk
    blt2tuk [OP] Well-Known Member
    Franklin, North Carolina
    1996 Toyota Tacoma
    Does anyone happen to have a picture of a stock set of leaf springs from an ext cab v6?
  2. Jun 11, 2015 at 10:09 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have a set on my parts truck. You just want pics? I really can't get a pic for a couple days, though. Laid up in the hospital for a bit longer.
  3. Jun 11, 2015 at 10:33 AM
    blt2tuk
    1996 Toyota Tacoma
    Yes jus lookin for pics for some comparison
  4. Jun 11, 2015 at 10:53 AM
    koditten
    Kirk
    Central Michigan
    OK. As soon as I can, or maybe someone else can help before I get a chance.
  5. Jun 11, 2015 at 11:04 AM
    blt2tuk
    1996 Toyota Tacoma
    That would be great. Thank
  6. Jun 11, 2015 at 11:27 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    what is it you are looking for?
    the 2wd base models use the 3 leaf leaf springs, that means there are 2 long leaf springs and the big thick main leaf.
    the 2wd prerunners and 4wd trucks have 4 leaf leaf springs, that means there are 3 long leaf springs and the big thick main leaf.
    the 4 cylinders and the 6 cylinders use the same springs in the rear and only the front struts are different
    not really sure what a picture will tell you beyond that
  7. Jun 11, 2015 at 11:29 AM
    blt2tuk
    1996 Toyota Tacoma
    I'm trying to figure out how the rear of my truck is lifted. And I have what appears to be half of a leaf spring. I will post pix when I get back to the truck p
  8. Jun 11, 2015 at 11:46 AM
    keakar
    karl
    louisiana
  9. Jun 11, 2015 at 11:53 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    How do you have half a spring?
  10. Jun 11, 2015 at 11:55 AM
    blt2tuk
    1996 Toyota Tacoma
    Like half of it is broke off behind the u bolts and is missing
  11. Jun 11, 2015 at 11:57 AM
    blt2tuk
    1996 Toyota Tacoma
    I will post pic when I get of work and back to the truck
  12. Jun 11, 2015 at 1:22 PM
    keakar
    karl
    louisiana
    oooohh that's not good but its not uncommon to have a spring break on you as can be seen in this thread. https://www.tacomaworld.com/threads/broken-leaf-spring.182686/
    the spring sits directly on top of the axle pad, if there is a spacer block between the leafs and this pad then that is used for a lift. it is also done but bending the springs with more arch to them so there are different ways lifts can be achieved, also longer drop shackles can be added to add lift.
    take pictures of the springs and measure the bolt to bolt spacing for the drop shackle and see how many rows of leafs there are and if there are any numbers stamped on top of the leaf springs.
  13. Jun 11, 2015 at 1:27 PM
    blt2tuk
    1996 Toyota Tacoma
    Will do. Like I say. If it has an aal I wanna ditch it and put some shackles on there for better rear flex
  14. Jun 11, 2015 at 1:35 PM
    keakar
    karl
    louisiana
    well can you tell us what you know about what you have for a lift and any other suspension mods you have so we can give you good advice on new leaf spring options?
    personally I think your better off with a set of general spring HD leafs to get like a 1"-2" lift over stock and then maybe a drop shackles to get you another 2" of lift and if you need more lift then add a spacer block to get you the rest of the way. I am not a fan of high lift leaf springs because I don't think they give you the best ride because of the heavy curve to them.
  15. Jun 11, 2015 at 2:51 PM
    blt2tuk
    1996 Toyota Tacoma
    fcbb1766b92ef1064ff2b9ae7d8d96a3_8f7f59fcfa203e055913b1b4e1ec69d0c0678a79.jpg804fb48ce8fca0b7b909ffac858a8521_af81d6a4c51296be97dfd6d8f78da067c0e12df3.jpg2f8c1f5623409cfe44dc3a42027d5d93_68efce7f8d43d3ee7aea4b613d20715dd0cba2c5.jpg
    First pic is of the side I think is broke. Second pic is off the passenger side that looks good. And third pix is of the shackles on my truck now. As for lift right now. It has some spacers up front. And I'm trying to figure out what it has in the back. I just ordered some bilstein 5100s all around and eibach coils for the front. Just trying to decide what to do with the back
  16. Jun 11, 2015 at 3:37 PM
    keakar
    karl
    louisiana
    I see nothing in those pictures to indicate its lifted at all, it looks all stock to me so what makes you so sure its lifted?
    prerunners (which appears to be what you have) come with the higher sitting stance just like the 4wd have, is that what you are talking about when you say your truck is lifted?
    unless you need "lifted" leafs, I would suggest you buy these springs for it: http://www.generalspringkc.com/product_p/90-173hd.htm
    the 4wd and 2wd prerunner both use the same springs for both, the heavy duty springs give you 400 lbs extra payload capacity
    no matter what springs you buy keep in mind there are 3 different lengths of them depending on the year of your truck so pay close attention to that detail
  17. Jun 11, 2015 at 4:12 PM
    blt2tuk
    1996 Toyota Tacoma
    Well I was assuming it was lifted because it's sitting on 33x12x5 on stock Toyota wheels nothing
    There is a big difference between the green 4wd on 33s and my other red 4wd on 31x10.5
    That's why I was assuming it is lifted in some way
  18. Jun 11, 2015 at 4:27 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    image.jpg image.jpg image.jpg These are stock springs, no lift, with 35's. I can almost drop the tire to slider height, which is pretty damn good for stock springs
  19. Jun 11, 2015 at 4:51 PM
    blt2tuk
    1996 Toyota Tacoma
    Nice truck and flex. Regardless of mine that one spring is still broken so I will be pulling a set of stock leafs off a parts truck. As stated above I ordered 5100s and eibachs for the front. Will shackles do for the back of it, ifdoesn't match height wise to the front?
  20. Jun 11, 2015 at 5:15 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Yea you should be able to run a longer shackle to level it out. If I was you I'd level the front to match the rear
