Leak prevention between cap and bed for 3-G Tacoma: Is There a "Best" way?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Idig63, May 8, 2017.
  1. May 8, 2017 at 10:16 AM
    Idig63
    Idig63 [OP] Well-Known Member
    Seattle
    2017 TRD OR 4X4 DCLB BLACK
    I've searched and read many threads on 3-G Tacos regarding water entering into the bed between the cap and the bed due to (faulty) design of the railcaps (especially at the front behind the cab). From what I've gathered, there have been some successes, but many non-successes, at making it "waterproof." At this point, I'm left understanding that it is either hit or miss making it waterproof.
    I will be getting a cap (Leer 100XR) installed next week. Before then, I'd like to do my best to waterproof the top of the bed/railcaps before the cap is installed.
    For those with caps/experience, is there an understood "best way" to achieve waterproofing that I may have missed?
    Thanks.
    BountyOR_VF2 likes this.
  2. May 8, 2017 at 10:22 AM
    mkivr32
    mkivr32 Well-Known Member
    Dan
    Long Island, NY
    2017 White TRD Pro MT
    Having issues with my 100XR as well and would like to know the same thing. Mine seems to be leaking up front and at the rear. It seems like it wicks from the rear glass forward with the lower part of the headliner. I trimmed the carpet some since it was sticking out but still seems to leaks. I'm hesitant to bring it back to have them fix it since I'm sure they will just throw a shit load of caulking at it and would rather fix it correctly.
    Paris0514 likes this.
  3. May 8, 2017 at 10:43 AM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    100XR? Been there, done that. May god have mercy on your soul.
    0. Use a butyl-based sealant, such as asphalt or roof sealant. Available at Home Depot and very cheap.
    1. Take off the front header rail. Pop out the rubber caps on both ends, seal them, then run bead of sealant UNDER the rail, then mount the rail back into original position.
    2. Fill the gaps on both ends of the rail as much as you can. In fact, overfill them to the sealant is a bit higher than the adjacent rail.
    3. If your cap will have a front removable window, it'll leak around the perimeter of the window.
    3.1. If the front window also has a slider, it'll leak in the slider.
    4. If your cap has windoors, they will leak around the perimeter.
    4.1. If your windoors are sliding variety, they will leak at the slider.
    4.2. Can you guess what the locks on your windoors will do? If you guessed "leak," you're a winner!
    5. Before installing the Leer canopy, take off your bedside caps (plastic ones along the top of the bed sides) and apply sealant underneath them. Also consider adding some thin (1/8") weatherproofing to act as padding between the cap and the bed, otherwise the cap will scratch the paint underneath it once the canopy is on.
    Fuckin' enjoy.
  4. May 8, 2017 at 11:22 AM
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Somebody mentioned this stuff and I'm about to order some:
    https://www.amazon.com/gp/product/B001AQ0FVC/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
    Just had the 100xr installed 3 weeks ago. Its actually fairly water tight. The only spot I get leaks is at the corners at the front of the bed. I can see a small gap so I'm hoping this'll seal it right up. It'll probably be a mess if I ever remove the topper but not sure I will. Just gonna buy a piece o shit trailer to haul mulch, etc.
    Anyway, I also notice some larger gaps where the topper back window meets the tailgate. Amazingly these don't seem to leak so I'll probably just leave it. Weve had a couple heavy rainstorms so I'm hoping these won't leak much in the future.
  5. May 8, 2017 at 11:37 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    When I had my ARE V series installed, a part called a "Tacoma bed gasket" was used and I have no leaks. I have no carpet so I don't have to worry about wicking, but it seems there is a part missing on some cap installs.
    EagleUSMCRet likes this.
  6. May 8, 2017 at 11:41 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  7. May 8, 2017 at 11:49 AM
    trdacevedo43
    trdacevedo43 Well-Known Member
    Edgar
    SoCal
    2017 DCLB Sport
    Great product to use
    oldschoolczar[QUOTED] likes this.
  8. May 8, 2017 at 11:49 AM
    GORUCKtaco506
    GORUCKtaco506 Well-Known Member
    Glenn
    Orange County, Ca
    2016 TRD Sport 4x4 DCLB Super White
    ARE cx shell with windoors, carpeted sleeping platform, red LED map lights, LED vanity lights, tailgate vinyl inserts, glove box vinyl inserts, dog ramp, blacked front grill and white emblem, blacked badges, debadged tailgate.
    I got an ARE cx installed and they did a great job on sealing around the rails. I was having leaks come in from the front corners, right under the rails. I just put some black caulking in the corners and spread it with a putty knife. Haven't found any other leaks yet, good luck.
  9. May 8, 2017 at 2:35 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    smitty99[QUOTED] likes this.
  10. May 8, 2017 at 2:38 PM
    smitty99
    Scottsdale
    Yeah that 5200 marine sealant is no joke:rofl:
  11. May 8, 2017 at 2:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  12. May 8, 2017 at 5:38 PM
    oldschoolczar
    '16 DCSB TRD OR
    Well shit, got to test 'er out pretty good today. Not quite as watertight as I thought:
    BlakeM likes this.
  13. May 8, 2017 at 6:27 PM
    opentang
    opentang you're doing a good job
    Brandon
    2020 T4R TRD PRO
    These plugs are helpful, 99.9% dry with my Leer 100XQ
    https://www.tacomaworld.com/threads/rubber-plugs-for-gaps-in-bed-rail-available-now.420884/
    Idig63[QUOTED][OP] likes this.
  14. May 8, 2017 at 7:30 PM
    Vancouver, BC
    I used that product after it was recommended here and I wouldn't do it again. VERY difficult to cleanly remove. And when it dries, it's a very hard, plastic-like substance. It's better to use something that'll still be flexible and somewhat soft.
  15. May 8, 2017 at 7:57 PM
    Go Fish
    Go Fish Well-Known Member
    2022 SR5 4x4 DCLB
    Mine doesn't leak in any of those places. Otherwise there is some good advise in that post.
    My installer used what I think is referred to as dum dum. It's a non hardening sealer kind of like black putty. They didn't seal under the side rails and I have some leakage there. I had some drips at the front corners and I was able to squish the sealer in there better. So far so good.
    oldschoolczar likes this.
  16. May 8, 2017 at 8:09 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    This is "dum dum" or "elepahnt snot" as we called it before in the car audio industry and dealerships. Made by 3M. Works well for all sorts of stuff, but a pain to clean up. Is this the stuff @0210 was referring to also?
    https://www.amazon.com/3M-08578-Black-Strip-Calk/dp/B000PEZ1L4
  17. May 8, 2017 at 8:22 PM
    oldschoolczar
    '16 DCSB TRD OR
    Hell yeah! That looks perfect for the few spots I need to plug. I'll probably snag some of this..
    GPsevinSixx[QUOTED] likes this.
  18. May 10, 2017 at 4:20 PM
    Idig63
    Seattle
    Thanks everyone for your input into this thread.
    I'll post what I end up doing for leak prevention and how it worked (if at all) :rofl:
  19. Sep 3, 2018 at 10:34 AM
    jtom12
    jtom12 Member
    Hey guys, I am in the market for a bed cap, I own a 2018 double cab 5 ft bed. My top priority is having a waterproof bed for storage as I only have the back seat at the moment. Is there a brand that tends to have less leaking? I have heard snugtop is better than most, it is also more expensive than other brands. It seems that the leaking is hit or miss and the design of the bed itself and the quality of the installation are also major factors for leaking. I dont mind spending the money for a top quality bed cap but if it leaks I might as well just keep using my tonneau cover. Any advice would be appreciated!
  20. Oct 12, 2018 at 10:24 PM
    Mjkovalsky
    Mjkovalsky Member
    2018 Blue Tacoma OR Longbed
