Leaking brake light recall
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JTScribe52, Feb 23, 2023.
  1. Feb 23, 2023 at 4:47 AM
    JTScribe52
    JTScribe52 [OP] Well-Known Member
    Dan
    2018 SR5
    My truck needs the recall, but I was considering doing an LED light replacement of the third light along with a total tail. As far as I can tell I don’t have any leaks; is there any need to get the recall before I replace the light?
  2. Feb 23, 2023 at 5:03 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would do recall, and leave oem in there. Your taking a huge risk of it leaking. That could cost you headaches and $1000's out of your pocket later on. Headliner alone is $1500, plus whatever else may need to be replaced if it does leak.
  3. Feb 23, 2023 at 5:04 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    If you think there is no leak,then you can tell them that you don't want the recall. So they will remove your VIN out of the third brake light recall list. But you can have them replace it with peace of mind. It's really up to you. Your truck, your choice.
    I have a recall on mine but I haven't been out to the dealer yet. I have oil change coming up soon so I plan to tell them that I don't want that recall because I have a topper on there which it is in the way.
    They aren't touching your taillights, they only are replacing the brake light for free recall service. They don't care about your total tail kit. I have it on mine.
    If you have total tail kit that you haven't done,then just wait until after recall if you decide to do so. If you prefer to do it now, then feel free to do so.
    Stevie17 likes this.
  4. Feb 23, 2023 at 6:14 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    The thought of the dealer pulling my headliner made me shudder, so I did it myself and replaced w a @MESO 3rd brake light, which a better product imo. Brighter and removable from the outside.
  5. Feb 23, 2023 at 6:23 AM
    na8rboy
    WI
    Dealer actually did good job doing so. My guess each tech is a crap shoot. Now the body shop that had to drop it for roof repair wrecked it. They ended up having to replace it at their expense.
  6. Feb 23, 2023 at 6:31 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    The dealer does not replace you third brake light for the recall, unless it is leaking. They put a marine grade sealer around it and a new trim to go around it. IF there is a leak, they inspect for mold and standing water. If there is no mold or standing water, they will clean the headliner and reseal the light. If they can not get the headliner clean, they will replace it and the light. IF there is mold, they will remove the seats, carpet, padding and headliner. Have ServePro remediate the mold. Then will remove and replace the sound deading material on the floor. Replace the padding, carpet, brake light and headliner.
    VaToy and Stevie17 like this.
  7. Feb 23, 2023 at 6:35 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Do they have to do any of the repair from outside of the truck or is it all from inside? My dealer said the shell has to come off before they do the repair.
  8. Feb 23, 2023 at 6:53 AM
    rolled93slc
    Jerry
    Lynchburg VA
    Its outside, we charge half hour labor to move the cap to reseal the light. We don't make anyone remove it before they come in for the recall.
  9. Feb 23, 2023 at 7:13 AM
    eurowner
    eurowner Duke Sky
    Scoty
    That is at your dealership. My dealer will not touch my truck with its shell installed.
  10. Feb 23, 2023 at 7:32 AM
    rolled93slc
    Jerry
    Lynchburg VA
    WOW, not even if you are willing to pay them .5hr labor to move the shell back to do the job? I guess every dealer is different. We are willing to, to get the job.
  11. Feb 23, 2023 at 7:44 AM
    JTScribe52
    Dan
    2018 SR5
    Right, my thinking was if I want to replace the brake light, do I want to worry about the additional sealer on there?
  12. Feb 23, 2023 at 7:50 AM
    TAZMINATOR
    2017 Tacoma
    The recall says it's free to do so.. The dealers have no rights to charge for topper removal. It should be free. It shouldn't take too long to take the topper off. I am not paying for it.. The dealer is responsible to do it for free.
  13. Feb 23, 2023 at 7:56 AM
    eurowner
    eurowner Duke Sky
    Scoty
    If it was an OEM Toyota shell/topper made with the truck from day one at the factory and sold with it, I agree.
  14. Feb 23, 2023 at 8:05 AM
    rolled93slc
    Jerry
    Lynchburg VA
    The recall is free to the customer. And that is for a truck that is in stock configuration. Toyota has allowed enough time to inspect and reseal on a truck that has an unobstructed third brake light assembly. There isn't any allotted time in the recall to remove after market parts that are in the way.
    Slick Taco, Chew and blu92in99 like this.
  15. Feb 23, 2023 at 8:09 AM
    rolled93slc
    Jerry
    Lynchburg VA
    You can have them inspect it, and claim the recall, and just inform them, do the inspection only, do not apply the sealer or trim ring. That you will be replacing the light with an aftermarket light assembly.
  16. Feb 23, 2023 at 8:15 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    exactly
  17. Feb 23, 2023 at 8:54 AM
    OnHartung'sRoad
    For real? Where does it say they have to move the shell? Not that I want them to try, they’ll probably crack it like an egg or put it on backwards.
    Instead of removing the shell, I will just put marine grade sealant around the edge of the light and call it good. It’s underneath my Prinsu and RTT anyway. The next buyer can deal with changing all that after I put 300k+ more miles on it.
  18. Feb 23, 2023 at 9:02 AM
    OnHartung'sRoad
    Thanks that helped me to decide to go another route. Mine is not leaking yet so it’s preemptive. Appreciate the reply.
    rolled93slc[QUOTED] likes this.
  19. Feb 23, 2023 at 9:04 AM
    rolled93slc
    Jerry
    Lynchburg VA
    You can't get to the brake light with the cap on. Unless you want some 200# dude laying on top of it, trying to put sealer around your light.
    Toyota has a template that goes on around the light. It makes it so there is the proper bead of sealer around the light. Then you use a supplied tool to remove the excess sealer.
    You can not physically do that with a cap on. Toyota does not consider a cap being on for this repair. So either you remove it, or pay to have the dealer move it to access the light.
  20. Feb 23, 2023 at 9:09 AM
    MGMDesertTaco
