Leaking cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jimsmithrn, Nov 18, 2015.
  1. Nov 18, 2015 at 11:57 PM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    Have somebody in the cab while another floods the outside with water and see where the leak is coming from on the inside.
  2. Nov 19, 2015 at 12:07 AM
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    You can also try cranking the blower motors with the windows closed and spray soapy water on the outside around possible entry points
  3. Nov 19, 2015 at 4:00 AM
    gearcruncher
    Canadain bumper technician
    Mine was leaking at the seals where the roof racks go . Took it to the dealer and was told it was " NORMAL "
    I have never been back there since . Had to fix it myself ........again
  4. Nov 19, 2015 at 4:34 AM
    jimsmithrn
    jimsmithrn [OP] Well-Known Member
    Jim
    2016 Quicksand Tacoma TRD Off Road
    The roof rack seals on mine look poorly seated. How did you fix it?
  5. Nov 19, 2015 at 7:53 AM
    First Taco
    First Taco Well-Known Member
    Robert
    Wa
    TRD Sport 4by4 4.0
    Translate please?
  6. Nov 19, 2015 at 8:09 AM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    Toyota has had issues and tsb's on the 4 runner sunroof for the last 10 years. It's no secret that the design is not the best. The tube drains get clogged and kinked all the time. Plus the track tends to leak also.
  7. Nov 19, 2015 at 8:15 AM
    gmgoodwrench
    gmgoodwrench Member
    If you have a sunroof (?), there are 4 drains, one in each corner (usually). If one of the hoses comes off or if the drain hoses are plugged or pinched, you have a big chance of water leaking into the vehicle.
    But, it's under warranty, bring it to the dealer and let them figure it out. A good shop will have shower head attached to plumbing to allow the tech. to place water in different locations on the vehicle while looking for the leak. I have seen many crazy places leak water, from an unsealed body seams to gaskets miss positioned, but then again, I worked on GM vehicles.
    Oh yeah, if the vehicle has a lot of water in it, the dealer should pull out the carpet and insulation to let it dry to prevent molding.
  8. Nov 19, 2015 at 8:23 AM
    20 n out
    20 n out Member
    2016 TRD sport
    A good way to check drains is to open sunroof and poor a cup of water directly into drain (you will see them in corners of open sunroof). There is a channel so water won't get in cab. Water should drain out under truck behind front tires. Usually drains run inside and down the "A" post. If a cup of water doesn't drain under truck then they are clogged of disconnected. Good luck.
  9. Nov 19, 2015 at 8:29 AM
    20 n out
    20 n out Member
    2016 TRD sport
    Clogged OR disconnected. Not clogged of disconnected. (Damn spell correct on a phone)
  10. Nov 28, 2015 at 4:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    So the final solution was what?
  11. Nov 29, 2015 at 7:23 PM
    jimsmithrn
    Jim
    I took apart the back of the cab's interior. Actually much easier than I had anticipated. Took a hose to the vents with wife in the cab. Water was pouring in from around the vents. So, I put some marine quality silicone around the vents and put the interior back together. So far, so good.
    Doggman and TOMRR like this.
  12. Nov 29, 2015 at 10:16 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    It was coming in from around the vents and not through them?
    Are they not sealed from the factory or did you have sealant failure?
  13. Nov 29, 2015 at 10:21 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    May I ask why you didn't take it in? You purchased that warranty for a reason, so I would've used it.
    TOMRR and big_jarv like this.
  14. Nov 29, 2015 at 10:30 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Is the black thing in the picture the cab vent?
    Also what does it do? Sorry I don't mean to jack the thread.
  15. Nov 29, 2015 at 11:18 PM
    #35
    NutFlush
    NutFlush Well-Known Member
    Doug
    2016 TACOMA SPORT DCLB
    Yes. The design on the vent for the Access Cab looks better. The two vents on Double Cab do not turn up on the inside.
    big_jarv[QUOTED] likes this.
  16. Nov 30, 2015 at 3:46 AM
    #36
    jimsmithrn
    Jim
    The water was coming from around the vents. The seal is a piece of rubber on the truck's exterior that depends upon inward pressure to seal. It's not very tight so it permitted water to leak in to the cab.
  17. Nov 30, 2015 at 3:51 AM
    #37
    Clearwater Bill
    Billy
    Largo Florida
    All vehicles have had some sort of similar vent since around the early 70's. Obviously located in different places in things like sedans and SUVs.........
    Primary function as far as I can tell is to relieve cabin pressure when you close the doors with the windows up.
  18. Nov 30, 2015 at 4:44 AM
    #38
    jimsmithrn
    Jim
    I really dislike service departments. For something this easy, I'd rather take care of it on my own. I'll leave the real headaches for the pros.
    That and the whole project only took me an hour. Service department would have taken much longer and, in my experience, they wouldn't have fixed the problem.
    I should also note that my purchase of the Tacoma had nothing to do with the warranty. If I was purchasing for a warranty, I would have bought a Hyundai which has much better warranties. I wanted the Tacoma. The warranty is a bonus.
  19. Nov 30, 2015 at 6:30 AM
    #39
    ZachPrerunner
    Southeast TN
    Yeah I don't believe any of us simply purchased a Tacoma based on the warranty alone. I can see where the dealership could take forever just trying to locate the issue. Not trying to start anything, just curious. :)
  20. Nov 30, 2015 at 7:15 AM
    #40
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    The vents are a good place to look for leaking if you've ever had a car with water in the trunk- they're usually located on the sides behind the rear tires, usually covered by the wrap-around of the rear bumper. Hyundais had an issue with theirs for many years (used to work in service).
