Leaking Clutch/Brake fluid
Discussion in 'Technical Chat' started by IdahoTaco, Jul 17, 2009.
  1. Jul 17, 2009 at 9:26 PM
    IdahoTaco
    IdahoTaco [OP] Well-Known Member
    South East Idaho
    2005 Taco 4dr 6spd TRD Offroad White
    URD short throw shifter. Walker Racing 2.5 Front Coil-overs. OME Dakar Rear Leaf Pack. Walker Evans 2.0 Rear Shocks. HID kit 5300k.
    Loosing fluid slowly over about 4 month period. 2005 4dr Offroad shortbed 6spd standard
    Found the leak....
    My clutch master under my clutch pedal. :(
    Slow leak, but coating of fluid all over the place on the piston assembly and carpet.
    QUESTIONS:
    1. How hard is this to fix? I'm pretty good with everything but engine internals.
    2. Any tricks or hang ups I should know, or look out for? i.e. fluid spraying everywhere n' chit.
    3. Best place to get the replacement parts?
    Thank you to you all.........
  2. Jul 17, 2009 at 9:54 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I had mine replaced last december. I was going to do it myself, but decided I'd let someone else have the fun. Looked like it was more of a neck job than I wanted to deal with in the cold. Cost me about 325 to have it replaced at the dealer.
  3. Jul 27, 2009 at 7:53 AM
    IdahoTaco
    South East Idaho
    Well it's done :)
    no thanks to you guys. :annoyed: JK.
    All in all it was a knuckle scuffer at best.
    I disconnected the meatal brake line,
    then pulled the black brake fluid hose off the inner firewall.
    Removed the two bolts holding the Master Piston assy.
    Calipered the old piston and transfered the length for the adjustment setting on the new one.
    Took small black hose off old piston and put it on the new one, then slid it up into place and pushed the other end of hose back onto the inner firewall.
    Aligned the metal brake line and threaded it back on. (10mm)
    Put piston in proper place on pedal.
    And then 2 bolts back on (12mm)
    Bled Tranny like a brake, easy to find underneath.
    Bye for now.
  4. Mar 8, 2011 at 6:21 PM
    trg37
    trg37 Well-Known Member
    Tyler
    South Jersey
    05 Tacoma OME Full Setup
    I know this post is super old, but I am dealing with this right now. I am debating whether to bring it somewhere to get fixed vs. Trying it myself. I am not a professional mechanic, but I do do all my maintenance n my truck. I also installed my lift myself. I feel as though this is something I could do, I just hate working in those cramped spaces. Lst time I was working down in that area was to install my entire towing setup. I wanted to scream! Any insight, ideas, suggestions regarding my dilemma would be appreciated. Thanks so much.
