Leaking clutch master cylinder
Discussion in '1st Gen. Tacomas (1995-2004)' started by jaenicole28, May 19, 2016.
  1. May 19, 2016 at 3:14 PM
    jaenicole28
    jaenicole28 [OP] New Member
    Jaemie
    1998 Toyota Tacoma 4wd
    I have a 98 Toyota Tacoma 4wd.
    Replaced the clutch master cylinder two days ago. It was bled properly, working great, and then it completely lost pressure when I drove it for about 5 miles. Bled it again, had a little bit of slack, about half inch, would lose pressure every 5-6 times I used the clutch but immediately regained pressured when I pulled the clutch back up. Then completely lost pressure and use of clutch yesterday. attempted to bleed again, wasn't working, checked the brake fluid, and was empty. Refilled the brake fluid, bled it again, haven't had an issue with the clutch since. But I've checked the fluid twice since then and needed to add more fluid. Noticed today my clutch pedal was slippery and looked like there was fluid leaking from the master cylinder into the cab of the truck.
    I assumed that the clutch just wasn't bled enough and there were air bubbles still in the line. But now am not so sure.
    Any idea what the issue is? Because I'm at a loss.
  2. May 19, 2016 at 3:30 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    the master cylinder is bad take it back for warranty.
  3. May 19, 2016 at 4:16 PM
    jaenicole28
    Jaemie
    This would be the second time I take it back. It was initially replaced in December by my dad and his friend and the adjustment bolt didn't get tightened properly and the bushing broke. Could it be any other issue besides a bad part?
  4. May 19, 2016 at 4:17 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    3.4 or 2.7?
  5. May 19, 2016 at 4:17 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    doesnt matter.
    no
  6. May 19, 2016 at 4:18 PM
    jaenicole28
    Jaemie
    It's a 3.4
  7. May 19, 2016 at 4:18 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    your clutch should have come with a new reservoir preinstalled onto the cylinder. that should NOT leak. nor should the front seal of the push rod inside the cylinder. nothing should ever leak. you should never see brake fluid coming out of these places.
  8. May 19, 2016 at 4:22 PM
    jaenicole28
    Jaemie
    Thank you.
  9. May 19, 2016 at 11:44 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    2000 Work truck
    Super Springs
