Leaking coolant
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fabio760, May 18, 2015.
  1. May 18, 2015 at 7:47 PM
    Fabio760
    Fabio760 [OP] Active Member
    01 prerunner
    fox shocks, ebc pads, baer rotors, brembo drums
    hey guys I have a 01 pre runner and noticed I started developing a leak after some detecting I traced it to coolant from the thermostat/water pump area my question is now what's more likely to be the culprit a bad thermostat or water pump? The very morning on the day I encountered the problem I noticed my heater wasn't putting out hot air I usually run it for about 10 min to warm up my engine and head home from work any way thanks for any help guys
  2. May 18, 2015 at 7:51 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Water pump is more likely to leak. Your lack of heat is because of the lack of coolant
  3. May 18, 2015 at 7:58 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    A bad thermostat wont cause a leak, tho it could be coming from the thermostat housing. The more likely culprit is the water pump though. how many miles on the truck? ever had the timing belt or water pump replaced?
  4. May 18, 2015 at 8:06 PM
    Fabio760
    01 prerunner
    Truck has circa 160 thousand only 10 from me don't know if either has been replaced
  5. May 18, 2015 at 8:13 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yea it's probably the water pump then... It's always recommended to change out the timing belt while you're in there too.
  6. May 18, 2015 at 8:14 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '03 cbr600rr, '09 R1, '03 cbr954rr
    Yep water pump. Do the whole shabang. There's a timing belt water pump kit on eBay all genuine parts. Not too bad a job. Was overwhelming at first. Hardest part was the damn crank bolt. And juggling the ac compressor out of the way. Other than that it's pretty straight forward. Do it asap!! You do not want that pump locking up. Trust me;)
  7. May 18, 2015 at 8:17 PM
    NightProwler
    Harlan
    Maricopa, Az
    Fabio760 [OP] likes this.
  8. May 18, 2015 at 9:42 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
  9. May 18, 2015 at 10:35 PM
    NightProwler
    Harlan
    Maricopa, Az
    It says he's away till the 23rd though and may be a delay.. Not sure if u should wait or not. There's other kits though. Might be ok for another week or two. Unless its leaking pretty good... I can't remember how long shipping took. Don't think it was long. But he may be backed up when he gets back. Idk.. There's other kits though. But get the genuine oem stuff. Good prices there.
  10. May 19, 2015 at 12:46 AM
    ThunderOne
    ThunderOne Banned
    Mitchell
    Nashville
    1ST GEN OR GTFO
    PlastiDERP
    How much does the stealership usually charge for a WP and TB change? Mine was done at 56k, I'm close to 156k now.
  11. May 19, 2015 at 1:02 AM
    NightProwler
    Harlan
    Maricopa, Az
    I'm not sure and can't remember what others were saying they got it done for. But it was a lot. I wanna say 5-6 hundred. And that was strictly just the pump and timing belt iirc. Nothing else. Something like that anyways.
  12. May 19, 2015 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not necessarily the water pump itself leaking...the gasket material that seals the water pump to the block has sprung a leak. You can't repair that without taking the entire water pump off. And at that point...you replace the entire water pump because the bearings won't last much longer.
    Here's a writeup on a water pump replacement on a 96 3.4L
    http://www.lieblweb.com/waterpump.html
  13. May 28, 2015 at 5:50 AM
    Fabio760
    01 prerunner
    Is that kit legit OEM? Ebay seems to have become the new Chinese trading port from what I hear
  14. May 28, 2015 at 7:10 AM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yea it's legit OEM Toyota parts. At least from that seller (Aircabinman). I can't comment on other sellers but the parts I received from him were legit.
  15. May 28, 2015 at 12:14 PM
    Fabio760
    01 prerunner
    very cool thank you sir
