Leaking oil from oil filter housing. Catastrophic failure.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomatrddave, Jun 10, 2024.
  1. Jun 11, 2024 at 5:46 AM
    clg
    clg Well-Known Member
    2017 Off-road
    Drove home after engine was knocking and you saw a trail of oil.....oof
    OP, keep your mouth shut about your mistake. The truck started knocking, you shut it off and were towed home.
    Junkhead, RIX TUX, Barsoom and 5 others like this.
  2. Jun 11, 2024 at 6:28 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I’m sure the main bearings are damaged as well as the rod bearings. If the main bearings are damaged you will have low oil pressure and a bumping type sound from the bottom end. If you didn’t damage anything else the dealer may just replace the crank shaft and bearings.
    HondaGM likes this.
  3. Jun 11, 2024 at 6:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I would be very surprised if it was not this.
    OP. Get prepped for the visit. Speak to managers first, receipts in hand.
    Barsoom, TA2016[QUOTED] and HondaGM like this.
  4. Jun 11, 2024 at 6:45 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    OP says that this oil leak happened *before* taking to the dealer for an oil change. This means that this leak occurred months after the last change making it less likely that a dealer tech did anything to cause it. I'm curious what the dealership will find.
    Good luck to the OP.
  5. Jun 11, 2024 at 7:09 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    This is what happens when they took auto shop out of high school. My car is making horrible noises and is leaving a trail of oil but I will keep driving it because I can’t make it worse can I?
  6. Jun 11, 2024 at 7:27 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    If the housing is cracked, it's stressed. That is the type of thing to happen a while after the oil change was done. Unless he is seeing what he thinks is a crack but isn't actually a crack. Since he was planning to take it to the dealer for an oil change today, I am assuming he took it to the dealer for oil changes previously as well.
    HondaGM likes this.
  7. Jun 11, 2024 at 7:31 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I do my own oil changes, even on my brand new cars. I save the receipts and take pictures in case I need proof. I would never let a dealer touch my car, unless it's a warranty repair that I don't want to come out of pocket.
    The low level lube techs at dealers are usually very inexperienced. It's too bad it's not common knowledge that complete rookies are changing oil and rotating your tires.
  8. Jun 11, 2024 at 7:41 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    The very best mechanic's/tech's I have known, literally came from the farm with the addition of some training. As for doing mechanical work, see my tag line.
    HondaGM likes this.
  9. Jun 11, 2024 at 7:42 AM
    BLtheP
    Plano, TX
    When you increase rpm, you get a lot more oil pressure, creating a lot more film. My guess is that it will not make any noise when the fix the leak and get good oil pressure again. What the dealer does after that is a guess, but I don't have high hopes.
    jmneill, Chew and HondaGM like this.
  10. Jun 11, 2024 at 7:50 AM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    What a nightmare. Sorry to hear this. Even though I have free oil changes for life via my dealer (every 10k) I refuse to let them work on my truck. Tire rotation only unless a real ASE tech is needed for warranty work. Between the least experienced guys doing the work, cheap oil out a drum, and the crap OEM filter that’s only rated at 50% efficiency at 20 µm I’ll pass and spend the money just do it myself.
    faawrenchbndr and HondaGM like this.
  11. Jun 11, 2024 at 7:51 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    True but you also get faster rotation and much more stress. The knocking noise heard is the extra gap created by the damage bearings.
    Any car I have ever seen with the start of rod bearing failure usually shows up when you rev the engine. Most my experience comes from turbo 4 cylinders.
    HondaGM likes this.
  12. Jun 11, 2024 at 10:59 PM
    David2431
    David2431 Well-Known Member
    Sometimes I feel goofy doing it, but I keep a large piece of cardboard under my vehicles-not to catch drips, but watch for evidence of them. I know bare concrete could suffice but cardboard works for me.
    Barsoom, Vmax540 and Taco22trdor like this.
  13. Jun 12, 2024 at 2:17 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    If it does crack while doing it yourself; you did it wrong.
    It absolutely WILL NOT crack if you properly change out the filter and properly reassemble and tighten the housing yourself.
    Trust in thyself, not a low level Stealership lube tech.
  14. Jun 12, 2024 at 2:45 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Suggesting he lie is never an option.
  15. Jun 12, 2024 at 3:17 AM
    #35
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    It all depends on how much oil he lost before and the way home . The knocking for sure put wear on the engine . Now how much wear .? Who knows
  16. Jun 12, 2024 at 3:31 AM
    #36
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    from the information given in the first post, that engine is toast. He didn’t give a distance of what the drive was, but “horrible knocking” is it something that just adding oil will fix. That is a 99.999% chance of spun bearings
    Chew likes this.
  17. Jun 12, 2024 at 5:32 AM
    #37
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    Barsoom likes this.
  18. Jun 12, 2024 at 5:39 AM
    #38
    clg
    2017 Off-road
    Catastrophic amounts. Engines don't leave trails of oil and start making noise until they've lost enough lubrication that things are starting to chew themselves up, none of which results in a quick or economical fix. A spun bearing = replacement of the crank and bearings at minimum, as well as line boring of the journals. Entirely doable for a competent machine shop, way beyond a Toyota dealers abilities. Considering it's the result of either a failed component under warranty or improper practice by the kid doing oil changes at the dealership, the likely outcome here is the dealership replacing the entire engine.
    Chew likes this.
  19. Jun 12, 2024 at 5:39 AM
    #39
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I am curious to know what happened. Who is the blame and how much damage did the engine suffer if any.
  20. Jun 12, 2024 at 5:55 AM
    #40
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Sorry if this was already asked, but how long between the last oil change and this "catastrophic" event? Or was OP getting ready to take the truck for its first oil change?
    If it already had its first oil change and a decent amount of time has passed, the dealer (or whomever did the oil change) might say it's not their fault.
    mquibble, Chew, mattm55 and 1 other person like this.
