Leaking rear end help
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03woodtaco, Oct 24, 2020.
  1. Oct 24, 2020 at 11:47 AM
    03woodtaco
    03woodtaco [OP] Well-Known Member
    Northeast CT
    03 Base 4x4
    Lift, 33’s, warn winch, custom grill assembly
    Any one got some advice on a leaky rear end, it’s an 03 reg cab 4x4 that’s spent its whole life in the northeast, not really interested in swapping it out cause any one I get around here will most likely be as bad as the one I’ve got. I’ve got a friend who offered to braze it, he did one on a tundra. Any advice is highly appreciated Thank you!!
    wilcam47 likes this.
  2. Oct 24, 2020 at 11:54 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Is it rusted through? How bad? Some can be patched some need to be replaced.
  3. Oct 24, 2020 at 12:23 PM
    03woodtaco
    Northeast CT
    03 Base 4x4
    I’ll post some pics in the morning
  4. Oct 24, 2020 at 12:27 PM
    eon_blue
    Azusa, CA
    Leaking from the differential? Or leaking at the ends near the drums?
  5. Oct 24, 2020 at 1:09 PM
    03woodtaco
    Northeast CT
    03 Base 4x4
    From the diff
  6. Oct 24, 2020 at 1:28 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you can get it clean enough brazing might work.
    Buy a housing from the South shipping might be expensive.
    Some have welded on a new cover without pulling the differential if it is you doing it and you cook the bearings it is your expense
  7. Oct 24, 2020 at 1:35 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Kinda vague, is it cracked? Coming from the pinion seal, from the cover?
    Hobbs likes this.
  8. Oct 24, 2020 at 1:47 PM
    03woodtaco
    Northeast CT
    03 Base 4x4
    It’s weeping from the cover, like I said I’ll post some pics in the morning
  9. Oct 24, 2020 at 1:53 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Try tightening the cover bolts a little.
    Sounds like it is leaking at the gasket. I have doubts if it the leak is through the cover, if it isn't cracked.
    Many times a simple solution exists.
  10. Oct 24, 2020 at 1:54 PM
    wilcam47
    Will
    Bourbon state
  11. Oct 24, 2020 at 2:21 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    In this part of the world the covers tend to rust through if you don`t keep after them
    They are only about a 1/16" inch thick if that .
    No bolts to tighten it would be nice if it was that easy
    GQ7227, wilcam47 and Rachelsdaddy like this.
  12. Oct 24, 2020 at 3:30 PM
    03woodtaco
    Northeast CT
    03 Base 4x4
    Oh yes absolutely that part of the world, 3 months ago it was fine
  13. Oct 24, 2020 at 6:25 PM
    wjktdi
    wjktdi Member
    bill
    2001 Tacoma Prerunner, 2wd, extended cab
    My 99 4Runner rusted through. There are a couple of companies making complete patch covers that weld on. I took my third member out, stripped it down and had it welded. I found the supplier on a 4Runner site, if I can dig up the name I’ll post it.
    I think it would be very difficult to weld with the third member in the truck, but not impossible.
  14. Oct 24, 2020 at 7:13 PM
    wjktdi
    wjktdi Member
    bill
    Look for a Dorman 926-993 repair panel, I found it on eBay, it’s a weld piece that you have to cut away the rusted portion of your pumpkin. The part number could be 926-933, sometimes I transpose numbers!
  15. Oct 24, 2020 at 7:16 PM
    wilcam47
    Will
    Bourbon state
    They dont make replacement covers anymore?
  16. Oct 24, 2020 at 7:32 PM
    wjktdi
    wjktdi Member
    bill
    The rear end does not have a bolt on replaceable rear cover. It’s a stamped steel piece that’s welded from the factory, a poor design. On the 4Runners some guys are swapping Ford Explorer third members to get disc brakes. Mine had an e-locker that I wanted to keep. Look at yours and you won’t see any bolts on the back side, only on the front where the differential bolts in.
  17. Oct 24, 2020 at 7:33 PM
    wilcam47
    Will
    Bourbon state
    Ah ok I wondered about that
  18. Oct 25, 2020 at 4:05 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Thank the ever higher mileage standards weight gets cut everyplace it can.
  19. Oct 25, 2020 at 7:34 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
  20. Oct 25, 2020 at 7:47 AM
    wjktdi
    wjktdi Member
    bill
    That’s the one I used on my 4Runner. Make sure you get the right one, e-locker rear ends are different than regular ones.
    DJB1 likes this.
