Leaking shed roof at transition from garage
Discussion in 'Garage / Workshop' started by SR-71A, Jun 9, 2025.
  1. Jun 17, 2025 at 9:45 AM
    SR-71A
    SR-71A [OP] Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Thats a great point. I need to look into those and measure the profile of mine. I know I will need to replace the existing ones - half them are shot
  2. Jun 23, 2025 at 11:41 AM
    SR-71A
    Zack
    Southern Maine
    Thank you everyone for the suggestions. I ended up doing it the hardest possible way I could think of :rofl: (but also the cheapest way)
    50 ft roll of 10" aluminum flashing. Used some 2x4s as a guide and bent a continuous 29 ft piece. 3.5" up and 6.5" down over the corrugated tin - with a bend just under 90 degrees to fit my roof line.
    I managed to get it installed in one continuous piece - under the existing flashing AND under the existing drip edge that was hidden underneath. Talk about a miserable job to do by yourself in the blazing sun.. Nothing is screwed in place yet - had to knock off early yesterday afternoon due to the heat wave we are in right now. But I got a bunch of scrap 4x4s up there so the wind shouldn't move anything until I can get it screwed in later this week. Also have new closure strips to install at the bottom.
    After cutting the old flashing off and looking at the way it was built (multiple layers of flashing with seams next to each other) Im feeling somewhat confident this will be the fix I need. Best part is Im only in it for about $60-70 at this point. Not counting the gallon of roofing tar I scrapped off :rofl:
    Roofing tar scraped off, old flashing cut, and old closure strips peeled off. It cleaned up well.
  3. Jun 23, 2025 at 11:50 AM
    SR-71A
    Zack
    Southern Maine
    Final product
  4. Jun 23, 2025 at 5:10 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    As I tend to over do things I would seal the ends of the roofing pictured below with a polyurethane
    flashing sealant. With your new piece it should be well protected -- on the other hand if water ever did make it under there the sealant would stop it.
    This is the product, this stuff is tough and won't crack like "tar" products.
    Read the label carefully to make sure it is the polyurethane product.
    jbciv, soundman98 and SR-71A[OP] like this.
  5. Jun 29, 2025 at 7:25 AM
    SR-71A
    Zack
    Southern Maine
    Hope to be wrapping up this project later today. Would you guys run a bead of that polyurethane sealant on top of the foam closure strip before screwing the flashing down?
    The install guides from Union Corrugating indicate yes - but every video Ive seen of real world installations (other than their own) dont show any sealant used.
    I plan on one screw per rib (9 inches) as indicated by them. I have to imagine the will make things very tight - not sure if the sealant will be adding much at that point?
  6. Jun 29, 2025 at 7:28 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I go with the manufacturer recommendation.
  7. Jun 29, 2025 at 7:32 AM
    Glamisman
    Glamisman Well-Known Member
  8. Jun 29, 2025 at 1:28 PM
    Citron
    Citron Well-Known Member
    Oklahoma
    2012 Tacoma TRD Sport
    Generally, the closure has one sticky side against the roof. The screws go through the flashing, through the closure, and into the roof. Don't over tighten the screws as it will split the rubber washer and the screws will leak. The screws themselves hold the closure in place.
    SR-71A[OP] likes this.
