Leaking water pump 2TR-FE
Discussion in 'Technical Chat' started by 05RedTaco, May 8, 2011.
  1. May 8, 2011 at 9:05 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I was installing a hood scoop insert and noticed that there is pinkish residue splattered all over the front of the engine. It was on airbox, P/S reservoir, going down towards crank pulley... Next thing I check is my coolant reservoir and it has very little coolant left, below the LOW mark.
    The obvious thing I am thinking is blown gasket between water pump and block. Now this quite upsets me, because the truck is 2008 with only 33k miles, just out of warranty :mad:
    I bought the truck as certified Toyota vehicle, but I doubt that they will honor it due to all my mods :rolleyes: :rolleyes: :rolleyes:
    I can swap the water pump myself no problem. It costs $89 plus the coolant so around $100... My thoughts... I will buys some coolant and monitor the leak, if it gets worse or starts overheating, I will have no choice but replace it :eek:
    Anyone had this happen to their 2TR?
  2. May 8, 2011 at 9:14 AM
    VermonterLost
    VermonterLost Well-Known Member
    Devin
    Castleton, VT
    2014 F150
    Water pump is covered under the 5yr/60k warranty. They replaced mine under warranty at around 43,000 miles. I'm the 2nd owner. Yea mine cooked. Honestly I'm kind nervous when my warranty runs out, this things been about as reliable as my 97 ranger, not very.
  3. May 8, 2011 at 9:17 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    Damn that sucks are you sure is from the water pump? I've read from a couple of people here that their coolant reservoir leaks and they had to put a clamp on the hose or something like that.
    btw, did you change your hood for the one with a scoop?
  4. May 8, 2011 at 9:28 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Sorry to hear it. Mine has some seepage around the front of the block which got me concerned at one point. After monitoring my coolant levels for a while it didn't seem to be losing very much coolant.
    pics?
  5. May 8, 2011 at 9:30 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I ran a leak and took it in. My coolant cap wasnt holding pressure, they replaced it.
  6. May 8, 2011 at 9:33 AM
    05RedTaco
    Tony
    Scottsdale
    Hrm... Thats a good point... Therotically speaking it could be from reservoir dripping on pulleys/belt and splashing all over. However, there are no drips/puddles or leaks when the truck is not running... I can pull the reservoir and check the bottom for leaks, first thing, I would do.
    If its the pump, I will most likely change the pump myself. I don't like other people working on my vehicle...
    Ya changed hoods. Its been work in progress... The scoop insert was not in good shape. All mounting points were stripped and damaged. I made some studs and JB welded them to the mounting holes (ghetto...LOL)... New insert costs $100 so that was way cheaper. I had to get the scoop grille and guide which were missing and rivet those to the scoop insert. I will put some pictures up in my build thread once its all done :)
  7. May 8, 2011 at 9:37 AM
    afd23a
    The Dynamo of Dixie
    ^^This is a possibility as well and easier to replace than a water pump.
  8. May 8, 2011 at 9:41 AM
    05RedTaco
    Tony
    Scottsdale
    Here are the pics...
    Coolant Residue on P/S pulley and P/S reservoir.
    Coolant Residue on bracket right next to the water pump pulley.
    Coolant residue on alternator and airbox.
  9. May 9, 2011 at 8:19 AM
    05RedTaco
    Tony
    Scottsdale
    Possible... How do I tell?
  10. May 9, 2011 at 9:45 AM
    05RedTaco
    Tony
    Scottsdale
    Its dry...lol
    I was watching the engine while it was running and couldn't see any leaks whatsoever...
  11. May 9, 2011 at 11:53 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There is a weep hole on the bottom of the water pump. If the shaft seal is toast, there will be obvious leakage. There will be a line of residue running down from the WP shaft. Some coolant might be run off the WP pulley and be flung.
    It should be fairly obvious looking at the engine form underneath.
    I found mine going bad during an oil change. Warrantied around 36k.
  12. May 9, 2011 at 12:28 PM
    05RedTaco
    Tony
    Scottsdale
    Thats exactly what I am experiencing and seeing... Well I will try to take it to the dealer and see what they say...
  13. May 9, 2011 at 12:43 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    When it starts to leak, it's only a matter of time before the bearings seize. They don't run long in coolant when the grease is gone.
    Warranty work= 1-1.5 hr labor. Get it in ASAP.
  14. May 9, 2011 at 1:01 PM
    05RedTaco
    Tony
    Scottsdale
    The Taco is going in on Wednesday at 8am. The water pump is covered under 5year/60k warranty :)
    I hope I get my truck washed too... It needs it...LOL
  15. May 10, 2011 at 2:30 AM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    Just had the WP replaced under warranty at 40K on my 2TR. Leaking from the front seal, not the pump to block gasket..
  16. May 11, 2011 at 1:25 PM
    05RedTaco
    Tony
    Scottsdale
    Got the pump replaced under warranty and got free wash too :) I am happy camper :)
  17. May 11, 2011 at 1:28 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Which local area Toyota dealership took care of you? Just curious...
    Az
  18. May 11, 2011 at 1:30 PM
    05RedTaco
    Tony
    Scottsdale
    Camelback Toyota I got both of my vehicles from them...
  19. Jun 18, 2011 at 9:10 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    yea thats the water pump. mine failed at 41k miles. i took mine in to the dealership and told them whats wrong and two days later of my truck being in there i received a call comfimiring what i already knew. :facepalm:the front of my block looked the same.
