Leaks after synthetic
Discussion in '1st Gen. Tacomas (1995-2004)' started by JSpokane, Jul 31, 2024.
  1. Aug 1, 2024 at 4:43 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Good question......I also went with rubber ones....
    and they very slowly leak.........if u fill to fast they leak...
    after all that.......I would rtv the metal ones....
    ControlCar likes this.
  2. Aug 1, 2024 at 4:43 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    For these, and frankly everything, the high millage synthetic with the zinc is what I use. It's great oil.
    Williston and ControlCar[QUOTED] like this.
  3. Aug 1, 2024 at 4:51 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    I didn’t touch the half moons on mine with valve cover gasket replacement and I guess I got lucky, they are still holding.
  4. Aug 1, 2024 at 5:51 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I purchased an Airens Platinum 24 Snowblower a few years ago and went back to the dealer for some input on what kind of oil I should use for the first oil-change. Me: "This Airens oil on the shelf?" The three guys behind the counter all responded in unison: "The Kawasaki 5w-30." Me: "Why": It doesn't have a Kawasaki engine." Them: "High Zinc content". I got the 2 qts of Kawasaki oil. I believe it's conventional oil... I'll check and confirm back) $4.50 each and worth it since it's 20 hours from now on. I change at end of season regardless of hours....it seldom reaches anything approaching 20 hours. (It hasn't snowed here much the last three years ) I also use it on my John Deere Garden Tractor and my Toro trim mower.
    * Apologies in advance about another "oil change thread": It's a sickness. At least it's not Friday.... that has to count for something. :proposetoast:
    MadNachos[QUOTED] likes this.
  5. Aug 1, 2024 at 5:57 PM
    MadNachos
    Hehe, yeah, we are getting into the weeds here. Oil war incoming!!!
    Williston and ControlCar like this.
  6. Aug 1, 2024 at 6:52 PM
    O'Silver_Taco
    MD
    This is what breaks in nascar engines......that's what it was designed for.
    Valvoline VR1 Racing Motor Oil SAE 30 (valvolineglobal.com)
    and the best stuff to break in flat-tappet cams.
    Most high milage auto fluids dont usually refer to zinc or anti wear additives....
    it usually means it has esters in it to swell the seals a little to get a little more life of them......
    .......if you dont have leaking seals......that could be a bad thing, it be an early demise to already existing ones that are yet to leak....
    Williston likes this.
  7. Sep 24, 2024 at 10:06 PM
    JSpokane
    JSpokane [OP] Active Member
    Thanks for all of the responses and sorry for the late reply.
    The valve cover gaskets and sealed cam plugs, stopped most of the leaking. Did not replace the 1/2 moons. Now just a drop a day even if we are not driving it. doesn't look like the oil pan. I'll find it, just wanted to say thanks for all of the helpful replies.
    Williston and MGMDesertTaco like this.
  8. Sep 25, 2024 at 7:25 AM
    Glamisman
    Glamisman Well-Known Member
    Check the PCV valve and hose(s) too. If there is too much posative pressure in the crankcase due to worn piston rings and the PCV system cant handle it, it will continue to push oil past the seals/gaskets etc.
  9. Sep 25, 2024 at 6:51 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Sounds like the epoxy garage floor was looking for a reason to exist hehe
    JSpokane[OP] likes this.
