Leaky engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinchetaco, Oct 29, 2012.
  1. Oct 31, 2012 at 11:18 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    1.ask if they have had the TSB done
    2.if they didn't clean the engine, look for oil splatter in the area
    3.if they cleaned the shit outta the engine especially in that area, be worried :D
  2. Nov 1, 2012 at 10:21 AM
    pinchetaco
    pinchetaco [OP] Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    Well after cleaning the engine and driving it for two days it looks as if the seal on the cover is leaking badly and slinging it everywhere. It also looks like the cover is seeping a little. So I think I'll change the seal for sure and then possibly worry about the cover if that doesn't take care of the main leaking.
  3. Nov 2, 2012 at 5:47 AM
    BamaToy1997
    Bill
    Navarre, FL
    You are getting sleeeepy.....Very sleeeepy! You will give me your Tacoma and forget that you did it....
    That sucks. Make sure you follow some of the recommendations you have found here. It will be a bit of a job for sure. Good luck!
  4. Nov 2, 2012 at 6:03 AM
    pinchetaco
    Winston Salem, NC
    Well I'm thinking I can get away with changing the deal on the harmonic balance. Then ill see how it looks from there cause that's the worst leak as of now.
  5. Nov 2, 2012 at 6:08 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    op, what type of warranty do you have, if any? sounds like this would be covered under power-train. its not too late if you have the 7yr/100k, unless your over 100k. in that case best of luck.
  6. Nov 2, 2012 at 6:10 AM
    pinchetaco
    Winston Salem, NC
    No warranty that I know of. It's an 06 with 85000 on it and I believe my power train warranty ended at 60k
  7. Nov 2, 2012 at 10:08 AM
    joesmith
    joesmith Well-Known Member
    Alaska
    2005 Access Cab 4x4
    I have this same problem on my truck, its gotten worse over time just because oil is everywhere. I think it will be my big summer project next year since I don't have a garage readily available.
  8. Nov 2, 2012 at 6:10 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Not quite sure what I'm looking at in the PDF. But I'm guessing it's near the passenger side by the oil dip stick?
    I looked around that area on my truck from the top. Between the stick and pulleys. Mine looks nice and clean.
    07 with 57K miles. :cool:
  9. Mar 11, 2013 at 7:55 PM
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    Thread revival.How did the replacement go op? I just discovered the same leak. I am looking to do this myself as well. Any idea where to find a service manual?
  10. Nov 7, 2015 at 11:51 AM
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    My 2.7 doesn't leak a drop.. just rolled 120k I've always serviced it with Mobil 1 fully synthetic around 6k since I bought it with 7k on it
