Lean code! Need advice!
Discussion in '1st Gen. Tacomas (1995-2004)' started by toy-yo-yo, Jan 20, 2023.
  1. Jan 20, 2023 at 7:52 PM
    toy-yo-yo
    toy-yo-yo [OP] Member
    01 Tacoma 2.7 4x4
    Hey guys and girls this might be kinda lengthy but I’m desperate ,
    Side note, please don’t hate me for making yet again another post… about the dreaded p0171 code. But i am completely stumped, so here it is.
    I have a p0171 code everything iv done so far.
    Replaced-
    Maf sensor, both 02 sensors, pcv valve
    Now with everything Iv replaced I then got a code scanner, I was looking at the
    Stft an Ltft, stft stays around 1.5 to 3.0, Ltft is at 34.9 an these both are at idle.
    When I increase my rpm’s to 2000,2500,3000 my numbers don’t get any better, but only by a few digits example, my stft gets to -1.0 Ltft goes to 28.8.
    Now I know if it was a vacuum leak those numbers would get way better especially driving it. My maf is reading 2.58-3.0 g/s at idle and 15 just with increasing rpm’s.
    So with all that information it lead me to do a smoke test.
    When I preformed the smoke test the only smoke I had was coming from the egr valve modulator, which I don’t think it’s suppose to be sealed cause you can remove the cap and check/clean that filter inside of it.
    But like I stated that’s the only visible smoke I seen, so all this data is correct, would this be leaning towards fuel delivery issue? Bad injector? Fuel pressure regulator? Or fuel filter?
    Sorry again for the length of the thread and another posted but I’m completely lost
  2. Jan 20, 2023 at 7:58 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Change thread title. "HELP", "NEED HELP" are titles reserved for people who need actual help such as broke down/stuck on a trail with no way to extricate themselves or get assistance due to remote location.
    toy-yo-yo[OP] likes this.
  3. Jan 20, 2023 at 7:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Rename the title to Help with Lean code. "Help" is reserved for actual distress.
    Try blocking off vacuum lines, like from the purge valve. If its leaking it won't sound like a leak but will let unmetered air in. You can watch to see if the STFT % goes down rapidly.
    You may need to find a way to hook up a fuel pressure gauge.
    TnShooter likes this.
  4. Jan 20, 2023 at 8:08 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Best I can do at the moment... go through the docs again and see where you're at in the tree. Good luck and welcome to Tacoma World :thumbsup:
  5. Jan 20, 2023 at 8:10 PM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    Okay, my apologies for the thread title, still new to the page, but I’m definitely lost here with this code
    TnShooter and Bishop84 like this.
  6. Jan 20, 2023 at 8:17 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Maybe a huge vacuum leak.....check pcv valve hose and maybe break booster.....
    when booster goes out it creates a huge leak.....
    DB64 likes this.
  7. Jan 20, 2023 at 8:33 PM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    Are51 runner thanks for the pdf! When through the list an only things I really haven’t done is with the fuel side.
    O silver taco, brand new pcv valve and hose is good, never check the brake booster, don’t know why I didn’t but will definitely check tomorrow!
    Area51Runner likes this.
  8. Jan 21, 2023 at 12:57 PM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    O silver taco, as far as I can tell the brake booster is fine and so is the check valve that only lets air go it one way, I took carb cleaner and spray around everything didn’t change motor at all, so I’m guessing it has to be clogged fuel injector dirty fuel filter or failing fuel pump. Thoughts?
  9. Jan 21, 2023 at 9:42 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    Maf numbers are fine. If your ltft is high at idle and remains high under load, I’d suspect fuel delivery like you said. You mentioned a few usual suspects, or your fuel pump could be on the way out too. Good luck.
  10. Jan 22, 2023 at 6:12 AM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    Tacotu3 I’m going to go get a fuel pressure test today and try it out and see what it reads. Does anyone know the specs for what the fuel pressure should be? An how would I hook that up? Iv tried finding a thread but no luck. I suspect you have to hook it up through that banjo bolt closest to the firewall or could I go through the fuel line going into the fuel pressure regulator? Cause unfortunately mine doesn’t have no Schrader valve.
  11. Jan 22, 2023 at 8:51 AM
    TACOTU3
  12. Jan 22, 2023 at 11:52 AM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    Okay! Thank you so much for the threads! I will do this, this evening. An see what’s it’s reading an will get back on here and give an update thanks so much for everyone that commented on this thread giving advice! It’s very very much appreciated.
    TACOTU3 likes this.
  13. Jan 22, 2023 at 1:40 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    When you smoke checked it did smoke come out of the gas filler neck? I had issues with my actual gas filler neck with a lean code it was what smoked when I checked
  14. Jan 22, 2023 at 1:45 PM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    I didn’t have any smoke come out of the filler neck, not that I seen. Might do another test, just to double check.
  15. Jan 22, 2023 at 1:51 PM
    TACOTU3
    I wouldn’t suspect a vacuum leak at this point, with a vacuum lead you’d likely see your high fuel trims drop under load.
  16. Jan 22, 2023 at 3:07 PM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    Right and my fuel trims are not dropping but only slightly, an when I say slightly I mean from 34.8 to 28 on long term and short term goes to 1.8-3.0+ just like I stated in the earlier post
  17. Jan 23, 2023 at 11:13 AM
    O'Silver_Taco
    MD
  18. Jan 23, 2023 at 11:18 AM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    O silver taco I managed to get it, I just took off the banjo bolt closest to firewall and put an adapter in there. My truck was reading 46psi which is alittle high, and after doing some test I come to the conclusion that I have a bad fpr, so I have one on the way plus injectors
    TACOTU3 likes this.
  19. Jan 23, 2023 at 11:32 AM
    O'Silver_Taco
    MD
    After some checking it seems correct pressure is around 40, 41psi...
    so replacing the fpr is not a bad deal.....
    dont think that's your problem......
    And after watching that video on that hydro-locked 5vz......replacing the injectors in a timely manner may be a good idea too......
    those you dont want to try to get your last bid of tread out of.....
    one of those stuck open could cao an engine in a blink of an eye.....
    Damn sure dont trust any but the denso oem's.....
    Toyota Tacoma 2.4 2RZ, 2.7 3RZ, 4-Runner (CA Only) OE Replacement Fuel Injectors (fiveomotorsport.com)
    DB64 and TACOTU3 like this.
  20. Jan 23, 2023 at 11:53 AM
    toy-yo-yo
    01 Tacoma 2.7 4x4
    Definitely! Already got the injectors on the way along with a fuel filter fpr and in the mist of diagnosing all this my iac went out so I have one of them on the way too lol
    TACOTU3 likes this.
