LED accents?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drew-z, Feb 15, 2009.
  1. Feb 15, 2009 at 1:11 AM
    drew-z
    drew-z [OP] dude
    White 05 prerunner SR5 Double Cab
    AFE Brute Force CAI, pioneer touchscreen, pioneer flat series 12" sub/ custom box, window tint, HIDs, LEDs overhead, timbren suspension, BHLM, 2" leveling kit
    I have seen everyone changing out the gauge lights and the map/dome lights and ive seen the cupholder LEDs. i have the stock orange lights and am not changing them. has anyone added a small LED accent that shines down to the shifter and cupholders???
  2. Feb 15, 2009 at 6:59 AM
    killerken
    killerken Well-Known Member
    Philadelphia
    09 toyota tacoma dbl cab trd
    Access LE Cover Toyota Factory Nerf Bars Dynolock Tail Gate Lock
    I thought about the same thing. My company car has led accents and I love them.
    It would be really cool if their was a system similar to ford's where you can change the color.
    My ford has 4 led accents and cup holder lights.
    Ken
  3. Feb 15, 2009 at 9:34 AM
    trlove
    trlove Member
    Harrisburg, PA
    17 TRD Sport
    I put LEDs in the overhead console. I was inspired by my Wife's Passat. The LEDs shine down and illuminate the cupholder area. I wired them to come on when the headlights are on.
  4. Feb 15, 2009 at 10:52 AM
    drew-z
    drew-z [OP] dude
    i really like the way you did that. where did you get those lights??
  5. Feb 15, 2009 at 11:49 AM
    CAdiveTaco
    CAdiveTaco Well-Known Member
    Nor Cal
    2009 Taco DC LB Pre Runner TRD Sport
    Bed Extender, Bed matt, G4 Fold-a-cover, debadged, locked spare, taigate hoe clamp mod, TW stick
    That looks great! Are they operated by a independant switch? Where did you tap in for power?
    Thanks
  6. Feb 15, 2009 at 12:42 PM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    That's awesome! My ex-wife's Acura had the same thing, very subtle but a classy touch. Nice job!
    Rob
  7. Feb 15, 2009 at 12:57 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Why ford is going under :p
  8. Feb 15, 2009 at 1:22 PM
    irishpirate2000
    irishpirate2000 Advanced Super-troll Member
    The Berkshires
    07 TRD DC RR
    I have those in the car and would love any info on how you did it and where you got the materials...Perhaps a new posted mod???
  9. Feb 15, 2009 at 7:18 PM
    trlove
    trlove Member
    Harrisburg, PA
    17 TRD Sport
    Thanks for the comments.
    Do this at your own risk. This mod requires simple soldering and insulating your electrical work from shorts.
    In the overhead console you can tap into both 12 volts and ground. In the harness connector to the temp/compass tap into the GREEN wire for 12 volts and the WHITE w/ BLACK stripe wire for ground. The GREEN wire is the signal that the temp/compass display gets when the headlights are on for dimming the temp/compass display.
    The circuit is 12 volts thru a 470 ohm resistor to the (+) of LED 1, then (-) of LED 1 to (+) of LED 2, and then (-) of LED 2 to ground. See the attached circuit diagram.
    I got the LEDs from superbrightleds.com. The RL5-O5015 5mm LEDs match the factory orange dash. You can pick almost any color you want. I aslo got the panel mount bezels (LED holders) from them too. The resistor and wire came from allelectronics.com. Get the 1/2 watt resistors. I used 24 gauge hook-up wire.
    The overhead console is simple to remove. There is a screw in the sunglass holder to remove and the grab the front near the windshield and pull down (two spring clips will disengage). Be careful drilling the holes for the LEDs!
  10. Feb 17, 2009 at 6:54 PM
    irishpirate2000
    The Berkshires
    07 TRD DC RR
    Thanks trlove!
    Just what I was looking for.
  11. Feb 17, 2009 at 7:10 PM
    irishpirate2000
    The Berkshires
    07 TRD DC RR
    And that was a 470 ohm 1/2 w resistor?
  12. Feb 18, 2009 at 2:24 AM
    drew-z
    drew-z [OP] dude
    yea thanks man thats exactly what i was looking for
  13. Feb 18, 2009 at 4:06 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    yeah right that kit they install is probally 80 bucks but they mark a grand on your bill fo' sho'.
  14. Feb 18, 2009 at 4:19 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I did it to mine, but burned up the resistor for the cupholder behind the shifter. (wrong size resistor) -- I have soft white LEDs in my armrest compartment that are nice.
  15. Feb 18, 2009 at 5:25 AM
    trlove
    trlove Member
    Harrisburg, PA
    17 TRD Sport
    Thanks and yes, get the 1/2 watt resistors.
  16. Feb 18, 2009 at 7:21 AM
    drew-z
    drew-z [OP] dude
    can you post any pics of the armrest LEDs??
  17. May 17, 2010 at 11:18 PM
    MadScientist
    MadScientist Member
    Custom Led Dashlights/Radio
    i used some 5mm led's to spice up my gauges. using those i can put them anywhere and use any color combo, even slow rainbow which i have for my odometer. i also put a slow rainbow in my shifter light and it looks wicked
  18. May 17, 2010 at 11:48 PM
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    Rasta scheme... Do it.
  19. May 18, 2010 at 12:37 PM
    MadScientist
    MadScientist Member
    You know whats up:cool:
    Definitely gonna be my next color scheme, unless someone wants me to do it for there truck too!
  20. May 18, 2010 at 1:16 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    I'd say do it to mine but I just re-did all my LEDs. Post up some pics when you do it though.
