LED Bed Cargo Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Railtech, Nov 5, 2009.
  1. Nov 5, 2009 at 2:45 PM
    Railtech
    Railtech [OP] Active Member
    Alpharetta, GA
    09 TRD Sport DC 4x4
    Hi Everybody,
    Just wanted to share an easy and functional mod. Since the install of my undercover its pretty dark in the bed.
    I purchased a pair of these:
    http://cgi.ebay.com/ebaymotors/TWO-...5fRVQ5fTrailerQ5fCamperQ5fPartsQ5fAccessories
    I ran a fused 12V from the battery junction box to a switch I found at Walmart. Since these pull milliamps I didn't use a relay like I normally would for aux lights.
    They are about a 1/4 inch shorter than the tracks so they remain fully functional. They don't look very bright in daylight but are very effective at night or in the garage. If I ever get into the A pillar I will rewire to the dome light ground as suggested here and they will operate with the dome light and remote. You can see the LED switch on the 3rd pic, it too is protected by the rail.
    They ended up looking pretty clean and simple. A very simple install with some good functionality.
    Enjoy!!
  2. Nov 5, 2009 at 2:53 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Very Sweet, definitely a sleek and useful set-up.
  3. Nov 5, 2009 at 4:01 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Great looking mod. I'll be doing this is the near future. Great pics!
  4. Nov 5, 2009 at 4:16 PM
    cutothechase35
    cutothechase35 Active Member
    VA
    Silver Tacoma 4x4 TRD Sport
    Coming Soon: Mud Terrain 33 Pro-Comps Hella Bulbs 4" Lift TRD Intake URD Mass Air Flow Sensor Calibrator Roof Rack with light bar Bull Bar with lights The list go on, but the budget does not.
    Like them. Will be doing in the near future like them.
  5. Nov 5, 2009 at 4:17 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Good looking out man...nice post! :thumbsup:
  6. Nov 7, 2009 at 8:50 AM
    Taco Ron
    Taco Ron Male Member
    Very clean install.
  7. Nov 7, 2009 at 8:53 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Nice! Very clean install. How bright are they?
  8. Nov 7, 2009 at 8:53 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    thats pretty slick but maybe look into a pressure switch so when you open the cover they come on
  9. Nov 7, 2009 at 9:05 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    clean!!! Very nice
  10. Nov 7, 2009 at 9:10 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Thats a good idea, i dig
  11. Nov 19, 2009 at 6:20 PM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    I ordered some of those lights. How big of a hole did you drill through the side of the bed to run the wires through? Did you remove the big blob of plastic/wax where the wires come out of the back of the lights?
  12. Nov 19, 2009 at 6:37 PM
    riggsjt
    riggsjt Well-Known Member
    Jake
    Meridian,MS
    11 FJ Cruiser
    do you have a pictures with them on at night?
  13. Nov 19, 2009 at 6:48 PM
    2009Silver
    Wisconsin
    One was super bright when I lit it up on my workbench. I bought 4...:D
  14. Nov 20, 2009 at 7:14 AM
    Railtech
    Alpharetta, GA
    09 TRD Sport DC 4x4
    I drilled a 3/8 hole to run the wires I am pretty sure. I used sheet metal screws to mount the lights themselves. I did use a razor blade window scraper to cut around some of the goo. I used the blade to cut down first then trimmed to the back of the light. You are correct there was a good bit of glue used to seal it up. I didn't remove it all there was still plenty around the wires.
    They are pretty dang bright, I have used them quite a bit since the time change.
