Led bed light strips
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flounderman, Nov 15, 2022.
  1. Nov 15, 2022 at 10:26 AM
    Flounderman
    Flounderman [OP] New Member
    2017 White Tacoma XP
    Wanting to put bed lights in my truck would like to wire straight to the cab light any suggestions
  2. Nov 15, 2022 at 10:29 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    See what @mattgecko has to offer and search on here - plenty of options.
    Philrab, mtip and Tacospike like this.
  3. Nov 15, 2022 at 10:30 AM
    Tacospike
    Two Trucks
  4. Nov 15, 2022 at 10:39 AM
    Flounderman
    Got strip lights just wondering about best way to wire it to cab light what wires I’ll need to know to tap and what not!
  5. Nov 15, 2022 at 10:43 AM
    Tacospike
    Two Trucks
    Ah, you want to wire to the cargo light switch?
  6. Nov 15, 2022 at 10:44 AM
    Tacospike
    Two Trucks
  7. Nov 15, 2022 at 11:07 AM
    Flounderman
    Tacospike[QUOTED] likes this.
  8. Nov 15, 2022 at 1:33 PM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
  9. Nov 15, 2022 at 1:42 PM
    clip
    VA
    15 OR
  10. Nov 15, 2022 at 2:01 PM
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    I have these bed light strips and highly recommend them. Rather than wiring to the cargo light switch on the dash - I like having a push button in the back of the bed - when you need light you are most likely at the back of the truck. I would not like having to walk to the cab, realize my keys are in the house, etc. I definitely wanted a setup with the button right there. Also it is wired to the battery with its own fuse so doesn't risk any of the truck wiring.
    stealthmode and Flounderman[OP] like this.
  11. Nov 15, 2022 at 2:13 PM
    caribe makaira
    Caribbean, Puerto Rico
    A pin switch on the tailgate in parallel to the door switches resolves the LONG walk to the cab.
    Flounderman[OP] and Tacospike like this.
  12. Nov 15, 2022 at 2:15 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    used the pin switch included with the gecko light strips and it works great
    clip likes this.
  13. Nov 15, 2022 at 2:53 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I installed gecko strips. Ran hot wire to front up drivers side inside piece of flexible plastic shield. Grounded in rear. Mounted small switch near power outlet in bed. I also bought a strip for under hood. All works great.
  14. Nov 15, 2022 at 3:28 PM
    80sforlife
    80sforlife Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    is that as blue purple in person as it appears in the photo?
    Flounderman[OP] likes this.
  15. Nov 15, 2022 at 3:32 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    If I already have the OEM bed lights, is there a way to easily wire up LED strips to it?
  16. Nov 15, 2022 at 3:35 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    No this is more representative of the actual color
  17. Nov 15, 2022 at 5:05 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    You could pull the taillights and tap into the factory wiring that feeds the pigtail from the OEM bed lights. Someone on TW may be able to make a T-harness or know where to get one to avoid tapping.
  18. Nov 15, 2022 at 6:24 PM
    caribe makaira
    Yes, PM @daveeasa, he has a no cut solution to sell ya.
  19. Nov 15, 2022 at 6:58 PM
    Kllrbee
    Kllrbee Well-Known Member
    Tim
    Bloomfield, WI
    22 Army Green DCSB Sport
    Not a fan of the lights as its just not my style, but the dog looks badass in that lighting!
  20. Nov 15, 2022 at 7:20 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Here's my contribution.
    (4) Diode Dynamics RGBW strips tied back to their Bluetooth controller. Controller wired to one of the switches on a Nilight switch bank that I cut into the cubby door. The switch bank is wired down underneath the trunk and up to the front where it connects to the battery.
    Extremely bright setup and dimmable all the way down to 1%.
    IMG_9339.jpg IMG_9341.jpg IMG_9337.jpg IMG_9338.jpg IMG_9333.jpg IMG_9335.jpg IMG_9329.jpg IMG_9330.jpg IMG_9331.jpg
    Flounderman[OP], clip and skeletron like this.
