LED bed lights under rail mounting?
Discussion in 'Lighting' started by stump jumper, Apr 7, 2014.
  1. Apr 7, 2014 at 10:35 AM
    stump jumper
    stump jumper [OP] Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I installed some this past weekend. Unfortunately I broke them in one corner. I even commented to my neighbor that the corner was too tight. So I get to do it again. My question is even with a good cleaning it did not seem like the adhesive supplied with the lights was going to hold. I am wondering if I am better off just using the 3M tape from the git go. I even thought about a light bead of 100% silicone.
  2. Apr 7, 2014 at 10:51 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    are your lights epoxy or silicone ?
    3m makes hundreds of types of double sticky tape. some good. some bad.
    good 3m VHB tape takes 24-48hrs to fully cure and if the surface isn't prepped correctly it doesn't matter how long you wait or what kind of tape it is - it won't stick.
  3. Apr 7, 2014 at 11:01 AM
    stump jumper
    Bill
    Texas
    Lights come with the 3m adhesive. I believe the supplied adhesive would work fine but it seemed to be applied inconsistenty. There were dry areas. I believe the lights are silicone.
  4. Apr 7, 2014 at 11:05 AM
    XXXX
    sKiP
    05 Prius
    you mean the strips have 3m tape already applied to them? should be the full length unless someones getting cheap....where did you buy them and what are they?
    if the lights are silicone you can use silicone to mount them if you wish. chances are they are epoxy though. Post up a pic if you can.
  5. Apr 7, 2014 at 11:48 AM
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
  6. Apr 7, 2014 at 6:32 PM
    stump jumper
    Bill
    Texas
    they are the 5050 led waterproof strips from Ebay or Amazon. Material is springy and soft not firm. Brand is Superbrite I believe.
  7. Apr 10, 2014 at 9:28 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    I have had a strip from Amazon installed under my rails for 2 years, no problems at all. Came with the 3M adhesive on the back, and that's all I used. BE SURE to clean all surfaces with rubbing alcohol and let them dry before applying the adhesive.
  8. Apr 10, 2014 at 9:35 AM
    XXXX
    sKiP
    05 Prius
  9. Apr 11, 2014 at 12:29 PM
    stump jumper
    Bill
    Texas
    I cleaned the rails with alcohol. I think the adhesive was not good on the light strip I bought. Since I broke the original at one corner o bought a new roll. Adhesive looks better on this one. I am going to try without tape first.
  10. Apr 14, 2014 at 10:57 AM
    stump jumper
    Bill
    Texas
    Adhesive on the second is also failing. I bought some 3M heavy duty double sided tape. As soon as its gets warm enough around here I will be trying it out. If this stuff does not work I will be looking for some kind of liquid adhesive.
  11. Apr 14, 2014 at 10:59 AM
    stump jumper
    Bill
    Texas
    Adhesive on second set is also failing. I bought some 3M heavy duty double sided tape. As soon as the weather warms up I will be trying it. It the tape fails I will be looking for wome kind of liquid adhesvie.
  12. Apr 14, 2014 at 11:35 AM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
  13. Apr 14, 2014 at 12:52 PM
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    it starts out thick, but you can press it down to conform to the surface shape/contour. you don't have to use it on the entire strip, just every foot or so.
  14. Apr 14, 2014 at 2:10 PM
    stump jumper
    Bill
    Texas
    I bought enough for the whole strip so I will have 100% coverage. I am also going to clamp it overnight at least.
