LED brake bulbs with no hyperflash?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cadman33619, Jan 31, 2022.
  1. Jan 31, 2022 at 8:58 AM
    cadman33619
    cadman33619 [OP] Well-Known Member
    I'd like to get LEDs for my brake lights. What do i need to add to avoid hyperflash... or to make sure they work properly? I've seen a friend add resistors but that seems like too much trouble. and i've heard of 'flashers' but i dont know anything about them.
    any suggestions?
  2. Jan 31, 2022 at 8:59 AM
    Tacospike
    Two Trucks
    You shouldn't get hyper flash for brake, usually hyper flash happens for turn signals
    flashers are a module device that makes the brake rapid blink /flash
    2004Taco and 1bad2k like this.
  3. Jan 31, 2022 at 9:00 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Novita ep35 for turn signals
    Bubba’sTaco likes this.
  4. Jan 31, 2022 at 9:49 AM
    cadman33619
    ah... then i misunderstood. now i just need to select a good set of LED bulbs
    THANKS!
    Bivouac and Tacospike like this.
  5. Jan 31, 2022 at 5:30 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Buy them from a Good vendor lots of poor quality bulbs out there.
    Remember the Polarity.
  6. Feb 1, 2022 at 3:29 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    So, are you doing LED on brake or turn signal or both?
    With LED turn signals you need EP35 flasher (prevent hyperflashing). DO NOT add resistors or something like that - just swap the flasher and be good.
    With stop light you need a dual filament bulb (red and red) as the same stop bulb is also tail lamp marker. One is low intensity (marker), the other high intensity (stop). This is getting tricky because there are lot of bulbs that have a "leak" between two circuits. Meaning when when you apply stop light, your dash light might turn on. Or when you turn on your lights for night driving your Cruise Control might not work. The bad thing is that you will never see that information on the sale description, you will find out after you buy it and install. My stop light bulbs (dual filament) have leak from stop to marker circuit, but despite that little flaw these bulbs are excellent durability (I have them for more than 7 years now). So I added diode to the tail light wire to prevent from flowing the current backward into the dash when I step on brakes. That works well too.
