LED bulb question
Discussion in 'Lighting' started by JaxQuack, Feb 21, 2016.
  1. Feb 21, 2016 at 6:13 AM
    JaxQuack
    JaxQuack [OP] Well-Known Member
    Trey
    2015 Tacoma Crew Cab Prerunner
    i bought the LED interior kit off of Amazon, and rather than replace my license plate lights, I used that set for my reverse lights. it was actually unintentional as I thought the kit came with reverse lights. In the end, they worked and are better than the factory reverse lights... my only concern was if it was an issue since the original bulbs are listed as different sizes.
    Thanks in advance
    Trey
  2. Feb 21, 2016 at 6:17 AM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    What is the bulb size of the new LED reverse lights?
  3. Feb 21, 2016 at 6:20 AM
    JaxQuack
    Trey
    Honestly as far as I could tell, it's came with 4 identical ones for the map lights and plate lights. They were all in one bag. The others were for dome and vanity mirror
  4. Feb 21, 2016 at 6:26 AM
    PVT Pablo
    Paul
    Chesapeake, VA
    Got a link to the Amazon ad for what you bought? If it fit in the map lights and plate lights its probably a 194. A 194 pulls less amps and watts vs the 921 that was originally in that reverse bulb socket from the factory. You'll be fine. Realistically though, the difference between the two is negligible, especially if they are LED.
  5. Feb 21, 2016 at 6:33 AM
    JaxQuack
    Trey
