led bulbs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by heliman79, Nov 2, 2014.
  1. Nov 2, 2014 at 6:24 PM
    heliman79
    heliman79 [OP] Well-Known Member
    Tim
    loxley al (baldwin county)
    05 sr5 prerunner v6
    i had a strange problem trying to install led bulbs in my turn signals the other day,as soon as the bulb made contact with the socket it would pop the t/s fuse!, went through 3 fuses, the last attempt the bulb's plastic began to get hot and smolder, now i did try to use a 3157 amber because the 4157 are low/high wattage for running parklights and turn signals, my truck does not have drl so these should of worked right? i reinstalled the incadescent bulbs and not a problem. what type(brand) of led do you guys recomend?
  2. Nov 2, 2014 at 7:07 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    What year truck do you have? If you have a newer model 2nd gen with your turn signals integrated in with your running lights (toward the middle next to your grill), just simply replacing the bulbs with LED's won't work. If they are, you have to buy two modules to bypass the running lights
  3. Nov 2, 2014 at 7:26 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I use vleds.com for all of my leds. Turn signals are trickier than most other LEDs though because you often need to use a load resistor to keep from blowing fuses or getting that hyper turn signal flashing.
  4. Nov 2, 2014 at 7:32 PM
    MarkH
    MarkH Well-Known Member
    Mark
    San Jose, CA
    13 PreRunner TRD Off Road
    I have V-LED Triton Switchbacks in my 2013 for the front turn signals/DRL. You need to use the 3157CK base or you will blow the fuse as soon as the power is turned on.
  5. Nov 2, 2014 at 10:28 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
  6. Nov 3, 2014 at 5:49 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    The nice thing about the V-LED kit is the resistors are only running while the turn signal is activated. It's a really smart, well designed and thought out system. Their brightness is equal to or greater than stock. Far brighter than any LEDs I've seen or tried myself.
  7. Nov 3, 2014 at 5:05 PM
    heliman79
    Tim
    05 sr5 prerunner v6
    thanks guys, my truck is not equipped with drls, only lights up when turn signals are activated.
  8. Nov 3, 2014 at 5:06 PM
    heliman79
    Tim
    05 sr5 prerunner v6
    its a 05 prerunner v6
  9. Nov 3, 2014 at 5:49 PM
    heliman79
    Tim
    05 sr5 prerunner v6
    so it has to be the ck base? what does that mean?
  10. Nov 3, 2014 at 6:05 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    It's a designer base made by Calvin Kline. ;)
    But seriously...the "CK" in the part number indicates that the "pin out"
    of the wires at the base of the bulb are a bit different.
    This link shows you the difference. :wave:
    http://www.distantxtremes.com/blog/3157-vs-3157ck-what-is-the-difference
  11. Nov 4, 2014 at 4:07 PM
    heliman79
    Tim
    05 sr5 prerunner v6
    is this the same deal with the stop/tail lights?
  12. Nov 5, 2014 at 10:07 AM
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    I'm having the same issue. I have LEDs now with load resistors, no issues except the LEDs now aren't 360* LEDs so they only point forward. I replaced with 360* ones and as soon as the blinker was turned on fuse popped. I have DTRL but they are with a wire in the third hole which cause it smolder when turned on with new LEDs. Anyone know what's wrong
  13. Nov 5, 2014 at 2:11 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Look at the diagram in the link two posts up from yours. :rolleyes:
  14. Nov 6, 2014 at 7:24 PM
    mrkabc
    Art
    Corona, CA
    The stoplights don't flash, you are OK with LEDs there.
    It's the flasher that needs more resistance, which is the problem for the turn signal bulbs.
  15. Nov 6, 2014 at 7:25 PM
    mrkabc
    Art
    Corona, CA
    Why are your wires smoldering?!?!?
    How exactly did you install your line resistors?
    What LEDs are you using? Pix?
  16. Nov 7, 2014 at 7:07 AM
    ajohnson225
    Austin
    Baton Rouge
    Resistor is wired on the positive wire like it's supposed to be. It fixed hyper flash on first set of LEDs. The second set came from Walmart. They were cheap so I figured why not. It's not the wire that's smoldering. It's the bulb in the socket that does. I should more clear there. It melted a little corner of the bulb plug. I returned them so no pictures.
  17. Nov 15, 2014 at 5:05 PM
    heliman79
    Tim
    05 sr5 prerunner v6
    i attempted to install my leds in the stop/tail lights and noticed the bulb would not seat and click in, would fall right out! looking at the base i saw that the "tabs" were slightly smaller than the filament bulbs, is there a certain brand that will seat properly and "click"?
  18. Nov 15, 2014 at 7:01 PM
    B737
    Kevin
    Jersey Shore
    stock
    for your tail lights, signals and reverse lamps, just buy those pairs from csjumper, he has the proper stuff for that. DTRL go with VLED.
  19. Nov 15, 2014 at 7:34 PM
    seafur
    seafur Well-Known Member
    Pacific Northwest
    2014 DCSB MT TRD OR
    Sprinter bed tiedowns, Aux fuse box, AIO key, 3-way canopy light switch, 12V bed outlet, Dual Battery AGM G35, Viair OBA, Uni-filter mod
    Started up my Tacoma with both map lights on, why I don't know just did, one of the LEDs from Superbirght stopped working. Guess I'll read what if any warranty they have.
