LED bulbs
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtlogger, Jan 22, 2020.
  1. Jan 22, 2020 at 3:56 AM
    vtlogger
    vtlogger [OP] Well-Known Member
    jerry
    bridport
    tacoma
    small 2" lift 32" tires
    Just switched my headlight bulbs for LED bulbs, now there’s no high beam indicator on the dash?? Is this just the nature of the beast when switching to LEDs??
  2. Jan 22, 2020 at 5:48 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    You need to have some resistance in the circuit. They make a short pigtail that has a resistor built in. Or, I made up a split one with two female plugs, one for the LED bulb, and the other for a standard bulb, which I stuck inside a little tomato juice can, and tucked it through a hole in the driver side inner fender to protect it, used these.https://www.amazon.com/Audak-Cerami...=1579700763&sprefix=H4+wiring,aps,184&sr=8-30 $7.99 vs about $20 for resistor.
    Das it mang likes this.
  3. Jan 22, 2020 at 8:21 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Unless you have retrofitted projectors I'd say :crazy: :smack: :facepalm:.
    se7enine and coopcooper like this.
  4. Jan 22, 2020 at 8:58 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    vtlogger[OP], se7enine and RysiuM like this.
  5. Jan 22, 2020 at 9:37 AM
    1997tacomav6
    Denver
  6. Jan 22, 2020 at 10:10 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    This is one reason why I got a light bar, for idiots who drives around looking cool with hid/led. I enjoy lighting them up at night! LMFAO
    RysiuM and 1997tacomav6 like this.
  7. Jan 22, 2020 at 3:00 PM
    vtlogger
    jerry
    bridport
    tacoma
    Jbrandt, wished I’d see that write up before, not really all that impressed with the LEDs. 1997tacomav6, i can see what your saying about fog and snow.. thanks for all the info, I’m going back to halogens
    RysiuM likes this.
  8. Jan 22, 2020 at 3:50 PM
    jbrandt
    Justin
    What year is your truck? I assume you have the post 2000 style with the replaceable bulbs, vs. the sealed beam style...
    Do a search for the “proper headlight upgrade” by the same guy, Crashnburn80.
    Essentially new oem style housings, an upgraded wire harness and super bright bulbs. I noticed a decent improvement just with the wire harness and my same bulbs (new housings). 5e bulbs are hard to come by now, apparently...
  9. Jan 22, 2020 at 4:21 PM
    vtlogger
    jerry
    bridport
    tacoma
    2003, I’ll check out the “proper headlight upgrade”
    thanks again for the info
  10. Jan 22, 2020 at 4:57 PM
    jbrandt
    Justin
    If you find you need more light that that, you either just need to go with an HID retrofit (spendy), or get an LED (or other) light bar for the roof (tho not road legal). But for off roading, that's where you want your light anyway.
    Good luck and enjoy!
