LED Cab Lights
Discussion in '3rd Gen. Tacomas (2016+)' started by Diego1931, Jun 2, 2016.
  1. Jun 2, 2016 at 1:27 PM
    Diego1931
    Diego1931 [OP] Well-Known Member
    Northern Ontario
    2016 Tacoma TRD Sport Inferno
    Truxedo Tonneau Cover Lund 5" Nerf Bars Shear Comfort Neoprene Rear Seat Covers Wilson Cell Booster Custom Aux Fuse Panel Interior LED Upgrade Tailgate Pop'n'Lock Console Divider Goodyear Wrangler Duratrax 245/75/17 Dewalt Tool Box POD Brake Controller Frame Rust A/C Mod Husky Weatherbeater Floor Mats In Progress: Tool mount brackets in bed D-Ring Bed Mod Under Hood Lighting System Inverter Cab Install
    Hey guys.
    I was reading a thread last night about led cab lights and decided I wanted to order the lights for my tacoma. For the life of me I can't find the thread. Can someone help? Or point me in the right direction? I'm looking to do map lights dome and vanities. Thanks
  2. Jun 2, 2016 at 3:50 PM
    chan2565
    chan2565 Well-Known Member
    2016 Tacoma TRD Sport Access Cab A/T
    LED lighting, Aux fuse box, Yaesu FTM-100DR
    I just did this in mine, as well as all the other lights around the truck. Gonna do a legit write-up and post it here whenever I get some free time. Here's what I used:
    http://www.amazon.com/Generation-Non-Polarity-Replacement-Brightness-10/dp/B00MAG6RMM
    (they also work in the license plate lights and the third brake light)
    The dome light is 31mm festoon bulb, so I bought these:
    http://www.amazon.com/Yorkim®-Festoon-Reading-License-Polarity/dp/B0142WSPA8
    The only problem is that it doesn't exactly fit, so you have to crimp the bases on each end to work :/ If you can find another bulb that is 30mm or has more pointed ends that would work better I think. All you need to replace the cab lights is a knife or a skinny flat-head screwdriver to pop the plastic lenses off. Just be careful on the map light lenses, there are three contact points and if you rip it out they might break. Also, you might need to use the tape trick to get the old bulbs out: just wrap some scotch tape around them, make sure it sticks to the bulb, and then pull slowly and it should come right out.
  3. Jun 2, 2016 at 4:04 PM
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    76559B9D-DA33-4BBD-88C1-C0FAAA240820_zps_62adbd99f533d606daef8a94eb0ffd7f6d6ce628.jpg These are what I got from superbrightled, a kind member here posted the part #s in another thread.
  4. Jun 2, 2016 at 4:56 PM
    laggz
    laggz Well-Known Member
    2016 Tacoma TRD Sport 4x4
    I got the kit from Amazon that included all of the interior lights. worked perfect!
  5. Jun 3, 2016 at 8:14 AM
    Diego1931
    Northern Ontario
    Alright this whole lighting thing has me confused. I'm looking at super brights and started with the done light. They have 4 options. What the hell is can bus and do I need it. DNASTY777 it looks like that's the one you ordered. For those of you that have already done this, can an oversized bulb fit in there or the map lights? I doubt that they would fit in the vanity ones. If someone could break this down into a 'for dummies' edition id appreciate it
  6. Jun 3, 2016 at 8:30 AM
    Crimsonfurious
    Crimsonfurious Well-Known Member
    2014 Tacoma XP
  7. Jun 3, 2016 at 9:01 AM
    dak2007
    dak2007 Well-Known Member
    2016 Blue SR5
  8. Jun 3, 2016 at 9:02 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
  9. Jun 17, 2016 at 6:17 AM
    tyler2009
    tyler2009 Well-Known Member
    Tyler
    NE Ohio
    2009 DCSB TRD Sport
    None
  10. Jun 17, 2016 at 7:43 AM
    Syndicate
    Syndicate Active Member
    2016 Black Tacoma DCSB TRD Sport
    Quality difference mainly. I pieced the Superbrightled kit together for my truck and bought a similar kit to the one you linked on Amazon for my wife's Highlander and there was a notable quality difference in both light and build. For most people it probably won't matter though. My truck is slightly brighter than my wife's highlander but she still enjoys hers.
  11. Jun 17, 2016 at 3:56 PM
    chan2565
  12. Jun 17, 2016 at 3:57 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    My LEDs possibly? Located in my sig
