LED conversion?
Discussion in 'Technical Chat' started by tacomaB, Aug 8, 2007.
  1. Aug 8, 2007 at 2:34 PM
    tacomaB
    tacomaB [OP] Member
    I was wondering if you could put a 3157 led bulb in the front signal/daytime running light without any problems. The existing bulb is a 4157 which apparently has more wattage because daytime running lights. I heard you will blow a fuse because of to much current allowed through the LED. If this is true, can you get a 4157 LED?
  2. Aug 9, 2007 at 4:37 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Why bother? What are you looking to gain?
    I've done LED replacements on my bike because of power savings for driving other devices (e.g. heated vests) as motorcycle alternators don't pump out as much power and it's a easy way to gain back some wattage. But they wound up being such a pain (unreliable). They also run considerably dimmer than incandescents, especially when not viewed from directly in front of the light.
  3. Aug 13, 2007 at 12:54 PM
    tacomaB
    tacomaB [OP] Member
    I wanted a white light look in the front...I have Hid kits for fog lights and headlights. I put LED's in for tail lights, but can't find and white daytime running lights. 4157 that is...
  4. Aug 13, 2007 at 2:28 PM
    Evil Monkey
    Robert
    Escondido, CA
    One guy on another Tacoma forum said he put the Switchback lights in his truck. They flash amber and run white.
    http://autolumination.com/3157_3156.htm
    Once you get to the site, do a search for Switchback. <ctrl-f> using IE
    I've also seen one guy who put a light silver paint coating over his stock bulb so it gives a white look when the lights are off.
