LED Dome Light
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssoulssurfer, Jun 18, 2018.
  1. Jun 23, 2018 at 9:59 AM
    ssoulssurfer
    ssoulssurfer [OP] Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    Gotcha thanks. I'm gonna get that one and another one try, only a couple bucks why not... Is there even any need to remove the resistor? If the lights functioning, currents not passing through the resistor right
  2. Jun 23, 2018 at 1:45 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    If light is on some current is pasding through resistor. But in small bulbs it is not much - if it is not super easy to remove, do not need to bother.
  3. Jun 25, 2018 at 1:15 PM
    ssoulssurfer
  4. Jul 16, 2018 at 9:23 AM
    ssoulssurfer
    https://www.superbrightleds.com/mor...s-led-bulb-18-smd-led-festoon-31mm/4015/8737/
    ^This thing is amazing how much brighter/better it is than not only the stock halogen bulb, but also the stupid LED bulb I got from Oreillys!
    Gets me wondering about changing the rest of the exterior bulbs. Has anybody tried changing the parking lights, or turn/brake lights like with this
    https://www.superbrightleds.com/mor...398/?year=1998&make=77&model=1618&scc_id=1428
    However, in their own video, looks like the LEDs are dimmer in this video...
    https://youtu.be/WbXuF5JLUS4
  5. Mar 16, 2024 at 12:40 PM
    AV8R4LIFE
    AV8R4LIFE Aircraft Mechanic
    Jonah
    St. Augustine Beach, FL
    Black/2004/Toyota/Tacoma/PreRunner/2.7L I4/2WD
    Forgive me if this is a dumb question, electronics are not my forte. I understand swapping the wires for your door switches to the dome light switch on the other side, but what are the jumper between 4 and 12, the terminated trace, and the cut resistor accomplishing? My door/dome light is out currently, I was going to try and replace the resistor but now you’ve got me curious. Thanks!
  6. Mar 17, 2024 at 3:32 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    It's been awhile since I did that mod. If I remeber it total eliminated the body control modules dome light control and made it function like the older trucks. My dome lights work with switch on light itself and only when doors are open and light switch is in door mode or on mode with doors closed
