LED Fogs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wingfiry, Feb 8, 2017.
  1. Feb 8, 2017 at 6:19 AM
    wingfiry
    wingfiry [OP] Well-Known Member
    Atlanta
    2016 TRD Sport 4x4 AC MT White
    I swapped out my factory fogs for some Morimoto LED Fogs from The Retrofit Source. Insanely simple and quick install.. (it took about 40 minutes total) and since I'm a bit old-school when it comes to fogs, I also got the yellow film to go over the fogs because yellow light actually cuts through the fog.
    I had my first chance to really try them out last night here in Atlanta as it was really foggy. I turned them on and the fog... vanished. I couldn't be happier with the results. I highly recommend these LED fogs.
  2. Feb 8, 2017 at 6:35 AM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Did you do just LED bulbs or did you do the complete assembly? Thank you
  3. Feb 8, 2017 at 6:57 AM
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    wingfiry[OP] likes this.
  4. Feb 8, 2017 at 7:07 AM
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    i installed the kit a couple weeks ago...they are awesome.
  5. Feb 8, 2017 at 7:11 AM
    wingfiry
    Atlanta
  6. Feb 8, 2017 at 7:13 AM
    goose443
    Austin
    Texas
    Awesome thanks for the response! I was looking at these... I'm just not sure if I want to spend $170
  7. Feb 8, 2017 at 7:26 AM
    wingfiry
    Atlanta
    There's a Tacoma World discount code on here somewhere.. ("TacomaWorld" I think) I think it knocked them down to $145. Not sure if the code still works, but worth a try!
  8. Feb 8, 2017 at 7:38 AM
    Scruffie
    Scruffie Well-Known Member
    Arsie
    Surrey B.C Canada
    2016 QuickSand Access TRD OR Manual
    265/75/16Dura,SSO Hybrid,X20,CruisinSliders,Skids
  9. Feb 8, 2017 at 7:39 AM
    Nwemerys
    Nwemerys Active Member
    Was thinking Rigid but I like the round better. Not sure how to remove the current lights...is it easy? Also, is there any room for adjustment of these once installed?
    Thanks.
  10. Feb 8, 2017 at 7:42 AM
    wingfiry
    Atlanta
    It's *very* easy. one screw and the whole unit tilts out. Installation is the reverse... slide the tabs in one one side and secure the other side with the screw. Adjustment is a screw for up and down. All you'll need is a #2 phillips.
  11. Feb 8, 2017 at 7:45 AM
    Nwemerys
    2017 OR...I assume you go in via the wheel well, or is there a way to attack this from under/overhead? Thanks.
  12. Feb 8, 2017 at 7:52 AM
    Scruffie
    Arsie
    Surrey B.C Canada
    I put some painters masking tape on my garage door where my low beams and fogs were hitting prior to changing them out. Spray paint on the ground where my tires sit in order to replicate in future if needed. Made it very easy to adjust my Moromito's XB's as they were quite a bit out. No adjustment was needed when I installed my Xenon HID's as they were right on the money. Excellent one two punch with these lights.
  13. Feb 8, 2017 at 7:55 AM
    Scruffie
    Arsie
    Surrey B.C Canada
    For the ease and the little time it takes, pull the grill and the plastic little side flaps for the easiest install. I tried taking part of the inner fender well off and going in that way but it was just to much of a pain in the ass for my fat short liitle arms.
  14. Feb 8, 2017 at 8:00 AM
    wingfiry
    Atlanta
    I went in from overhead. pop the hood and reach down behind the headlights. There's enough room to easily work. You might want to use a stubby screwdriver for the removal/install.
  15. Feb 8, 2017 at 8:01 AM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    I just installed the Rigid D2 fogs yesterday. I was able to do everything by reaching down through the holes in the radiator support frame.
  16. Feb 8, 2017 at 8:03 AM
    Aw9d
    Aw9d That one guy
  17. Feb 8, 2017 at 8:34 AM
    Nwemerys
    Great, thanks. I have a TRD Pro grill on the way so 2 birds with 1 stone.
  18. Feb 8, 2017 at 5:58 PM
    TVirus916
    TVirus916 Active Member
    2017 TRD OR DCLB 4x4 BBP
    I agree, in a good way. I would like to see OP's DIY pics.
    Aw9d[QUOTED] likes this.
  19. Feb 8, 2017 at 6:08 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    EB Group and gr0ver like this.
  20. Feb 9, 2017 at 6:59 AM
    wingfiry
    Atlanta
    I didn't take pics during the install, but I can take some pics of the finished product over lunch..
