Led hyper flash fix resistor???
Discussion in 'X-Runners' started by Blackfin2012, Jun 28, 2013.
  1. Jun 28, 2013 at 9:22 AM
    Blackfin2012
    Blackfin2012 [OP] New Member
    Bob
    Fort Worth, TX
    2012 Barcelona Red Tacoma Xrunner
    Turbo Airraid cold air
    When installing led lights to all your bulb sockets ie: blinkers! You must install one resistor for each light installed, so for example, four blinkers are led, four resistors are required for system to work. Is this correct???
  2. Jun 28, 2013 at 3:18 PM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
  3. Jun 28, 2013 at 5:44 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    just get the relay for LEDs. Kind of a waste to get LEDs then add resistors.
  4. Jul 2, 2013 at 7:55 PM
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
    • Cat Back Borla Exhaust System • Volant Cold Air Intake with Ram Air Scoop • Black FJ TRD TT 16” Wheels 285/75R16 BF Goodrich All Terrain T/A KO • Icon Extended Travel Front Coil-over Shocks • Icon Monotube 2.0 Aluminum Rear Shocks • Icon Tubular UCAs • OME Dakar Leaf Springs • Front Differential Drop Kit • OME Carrier Bearing Spacer Kit • Hardwired Cobra Radar Detector • Max Liner Floor Mats • Undercover Tonneau Cover • Black Powder coat Devil Horns, Made By Andres • TRD Low profile Carbon Fiber Radio Antenna • LED Map & Dome lights • LED front corner lights • LED Reverse lights • LED License Plate lights • Tailgate Hose Clamp Mod
    Take the stock flasher relay and remove the shunt resistor and solder in 2 .22ohm resisters (1watt) and your good. I have a 2009 pre runner that's what I did and it worked thanks to other members of TW and forum threads I got it working.
  5. Jul 2, 2013 at 8:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There is no solid state flasher available for 2nd Gen with DRL.
    You either need to use resistors or attempt to mod the resistance of the shunt in the flasher.
  6. Jul 2, 2013 at 8:46 PM
    tomtom
    The Desert SW
    2012 FJ
    That is some serious el stinko.
    I mean, what the hell, in this day and age of turning cars into sissy mobiles.
