Led interior lighting???
Discussion in '1st Gen. Tacomas (1995-2004)' started by little bear, Nov 21, 2014.
  1. Nov 21, 2014 at 4:56 PM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    Anyone have led dome lights? Where did you get them and was it an easy install?
    Thinking of running amsoil 5w 30 and amsoil severe gear in my tranny and differentials (2000 sr5 with 3.4 and 5 speed tranny) good idea?
  2. Nov 21, 2014 at 5:09 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Cjumpers leds! Look for thread.
  3. Nov 21, 2014 at 5:10 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  4. Nov 21, 2014 at 5:13 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Amsoil is ok. But your manual tells you the weight.
  5. Nov 21, 2014 at 5:22 PM
    little bear
    Barry Hobson
    Canadian, Texas
    No manual, old truck that I am just about to purchase.... :( what is a better oil?
  6. Nov 21, 2014 at 5:49 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Did the LED dome light, totally worth it. Can't remember what mine was called but it was as easy as switching out a bulb.
  7. Nov 21, 2014 at 5:54 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    You need to find out. You dont want to put the wrong weight in there!
    I purchased my reverse light leds 700 luman from Cjumpers on here. I am very happy.
    As far as the oil maker to use, apples vs oranges. Sorry.
  8. Nov 21, 2014 at 6:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    75W90 is the correct weight for the diffs and the t-case and the manual trans.
    A word of caution, the trans oil must be the GL-4 type. No GL-5. It will cause problems with the brass synchros in the trans. Make sure you do not use gear oil that has friction modifiers either. In the diff this does not matter but in the trans it does.
    Here is what I use:
    http://www.redlineoil.com/product.aspx?pid=46
  9. Nov 21, 2014 at 7:27 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I also run an LED panel dome light. Bought it on eBay. Install was quick and easy.
    Amsoil is good stuff! Your selections (5W-30 and 75W-90 Severe Gear) are spot-on.
