Led light bar instalation
Discussion in '4 Cylinder' started by tacomathunder, Nov 10, 2009.
  1. Nov 10, 2009 at 5:42 AM
    tacomathunder
    tacomathunder [OP] Well-Known Member
    Florida
    07 4 cyl reg cab
    pop-a-lock on tailgate, tailgate damper by ez down, extang platinum snap tonneau cover, rampage LED light bar, etrailer wiring harness, black led tail lights, tsi clutter catcher center console, griffin itrip ipod player,BHLM,35W DDM Tuning hid's 5000K, Day Time Running Light Mod, New Sony Stereo
    I'm getting a rampage Led light bar with the reverse light function. I have a 2007 Tacoma regular cab 4 cyl. I don't have the towing connections, so does anyone know what I have to do to get the brake, running, signal, and reverse lights to work, like what will I need to buy to get it to work on my truck?
  2. Nov 10, 2009 at 6:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think you will have to tap into the existing wires to the tail lights....May need a multi meter to see what does what. might help
  3. Nov 11, 2009 at 11:48 AM
    tacomathunder
    Florida
    07 4 cyl reg cab
    thanks, do you think maybe a T-connector harness and a little spicing would do the trick?
  4. Nov 11, 2009 at 12:01 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Just get a towing wiring harness from etrailer.com. It takes about 5 minutes to install and you can plug your light bar right into it.
  5. Nov 11, 2009 at 2:31 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    oh ok, thanks
  6. Nov 21, 2009 at 11:22 AM
    tacomathunder
    Florida
    07 4 cyl reg cab
    how do i get the reverse lights to work with the etrailer harness? is there an adapter i can buy or something else i can do, because i really want to buy th led light bar with the reverse light option
