led light wire gauges
Discussion in 'Lighting' started by brutalguyracing, Mar 14, 2010.
  1. Mar 14, 2010 at 6:20 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    is it ok to use 20-22 gauge wire to hook up some led strips in the bed on truck and does it require a relay????
    i plan on hooking them into the dome light
  2. Mar 14, 2010 at 6:38 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    LED light strips use a very small amount of electricity. It's probably OK but I can't say for sure - I'm not too knowledgable on the subject. I used 18g wire for my lights and they work great. I used to 3' strips of LED lights in the bed. They are AWESOME! I put them on switches.
    Why are you connecting it to the dome light? Do they come on when the doors are open? Do they come on when the dome is switched to 'ON'?
  3. Mar 14, 2010 at 9:46 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea it will be on a 3 way switch so u can have them on with switch "up" or off "center" on with dome "down"
    it will go on with the courstey lights or when the door is open or the remote button
    its in the cheap mods section
    where did u put them in the bed?
  4. Mar 14, 2010 at 9:49 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Yeah its fine. The prewired LEDs from Oznium come with 22 gauge wire already on them. Works fine.
  5. Mar 17, 2010 at 1:53 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    22ga is too small to go that far. one 18ga wire should be enough for multiple strips from cab to bed.
  6. Mar 20, 2010 at 6:16 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    all depends on the length of the wire...but i always think its better to go bigger...
  7. Mar 25, 2010 at 2:58 PM
    kevinva
    kevinva Active Member
    Virginia
    09 Double Cab SR5 4x4 Longbed
    Have you found an on-off-on switch that will fit in one of the Tacoma blanks? I have been looking for such a switch for wiring my bed lights but haven't come up with anything yet. I would like a switch that has an OEM look (i.e., it won't look obviously out of place with the other switches on the dash).
  8. Mar 25, 2010 at 3:42 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    try these
    http://sensing.honeywell.com/index.cfm?ci_id=140301&la_id=1&pr_id=149405
