LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. Feb 1, 2017 at 12:26 PM
    #281
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
  2. Feb 4, 2017 at 7:43 AM
    #282
    Greg Hall
    Greg Hall Well-Known Member
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    Hands down, the best $40 interior upgrade you can do. On the exterior, I just put TRD Pro LED foglights in yesterday and the performance is kind of addicting... now looking at in comparison to the headlights, looking into some LED hi and low beams. This was very helpful. Thanks
  3. Feb 5, 2017 at 8:07 AM
    #283
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    My LED bulbs washed it out quite a bit as well - adjusting the brightness & contrast of the RV camera solved most of the issue...
    FirstTacoma!! likes this.
  4. Feb 5, 2017 at 1:32 PM
    #284
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    I didn't know I could adjust that. I'll take a look. Thanks!
  5. Feb 6, 2017 at 7:36 PM
    #285
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    HID has the following flaws:
    • Ballasts burn out frequently, cause RF interference, and require large amount of power to start up. Without a relay setup you'll roast your light switch/wiring/BCM.
    • Bulbs will burn the interior of your fixture.
    • HID takes too long to start up, not good for auto headlight setup or flash to pass. (See first bullet point)
    • No effective low/high beam setup. You have to use ridiculous shutter systems or horrendously complicated bi-xenon setups.
    And there you have it.
  6. Feb 9, 2017 at 12:50 AM
    #286
    mrkabc
    Art
    Corona, CA
  7. Feb 12, 2017 at 4:18 PM
    #287
    Jyank
    Jyank Well-Known Member
    Gerald
    little rock
    2017 White 4X4 Tacoma TRD Sport V6 AT Access Cab
    Well I replaced my map lights and dome light. The maps were no problem at all, but the dome light was not quite right. Remember I measured the dome light bulb I took out and it was 31mm, well, after buying a 30mm and have it fit tight, I relooked at it and the installation. The OEM bulb has small tits on each end that fit into holes/depressions on the mounting fixture so even though I went with a smaller size bulb it was still tight since it did not mate with the hole(s). Lesson learned: Get a 28mm bulb and you will be golden.
  8. Feb 13, 2017 at 2:43 AM
    #288
    mrkabc
    Art
    Corona, CA
    Get one of these for your dome light:
    Look at this on eBay http://www.ebay.com/itm/282161662480
    48 LEDS, the bulb adapter is spring loaded so it will fit securely into the clips. Silver clip is positive, gold is negative. Tuck the wires above the clips and secure the LED array to your dome light fixture with the attached 3M tape. This beast will seriously light up your truck's interior and best of all emits little heat! At this price is a no brainer.
    Don't waste your time with a "kit" that has a cheapo 31mm LED slug that won't put out 1/4 of the light that this thing does. Enjoy!
    daohaus likes this.
  9. Feb 15, 2017 at 12:06 PM
    #289
    jLEE028
    jLEE028 Well-Known Member
    MKE
    i'm really thinking about getting the same HID setup from DD. have you experienced any burning/melting of the interior housing since you put these in?
  10. Feb 16, 2017 at 4:35 AM
    #290
    bowhun2r
    bowhun2r Well-Known Member
    Scott
    Steeler Nation
    19 - GX-460
    I have not and I've had these on 3 different vehicles. My 4Runner is going on 2 years using them w/o issue.
  11. Feb 16, 2017 at 4:47 AM
    #291
    jLEE028
    MKE
    nice! thanks for the info. will definitely get these then. you know if they ever run any specials or sales?
  12. Feb 16, 2017 at 4:50 AM
    #292
    bowhun2r
    Scott
    Steeler Nation
    19 - GX-460
    funny you ask....I just got this email from DD yesterday with a promo for free shipping "FEB01"
    Try that during checkout. It's for signing up for their emails...
  13. Feb 21, 2017 at 5:31 PM
    #293
    MDLIVINTACO
    MDLIVINTACO Trixie2.0
    C. Rob
    Maryland
    2017 TRD OF DCSB
    -Prinsu Design CabRac with Wind Deflector LED Cutout -Prinsu Noise Cancelling Strip -ARB Awning (2000) -ARB Awning Room -Tint -Lower Bumper Mounted LED LIght Bar Coming SOON..... -LED's -Lift -Roof Rack Light Bar -CB Radio -Narrow Mount Wind Deflectors -Snorkel
    Appreciate the write up man!
    chan2565[QUOTED][OP] likes this.
  14. Feb 22, 2017 at 11:17 AM
    #294
    808 FN-2199
    808 FN-2199 New Member
    2017 White Tacoma TRD Sport
    had hyper flashing with blinkers while headlights were on when using OP original set up. just changed the rear blinkers back to the factory lights and they work fine now. everything else is still LED.
  15. Feb 22, 2017 at 5:52 PM
    #295
    obz
    obz Well-Known Member
    Utah
    2017 Silver Sky TRD Sport 4x4
    I had the same thing. I tried multiple LED's and couldn't get it to stop. I swapped out the rear turn signals and it was fine. Everything else is still LED (tail lights).
  16. Feb 23, 2017 at 7:20 PM
    #296
    BBoyM3
    BBoyM3 Well-Known Member
    Bobby
    San Antonio, TX
    2025 White DCSB TRD OR
    Predator Tube Steps, Spray-In Liner, Toyota Larger Mud Guards, Expel PPF, Expel Tint (35% Fronts Only), NXTZEN Paint Coating, 17x8.5 +25 RRW RR5-S Black, and 285/70R17 Toyo AT3
  17. Feb 24, 2017 at 11:48 AM
    #297
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Anyone know if there is a switchback led for the daytime running light available for 2017?
  18. Feb 24, 2017 at 6:29 PM
    #298
    MoridinTX
    MoridinTX Member
    2017 SR5 Dbl Cab
    I'd like to know this as well. I believe our SR5 have different lights than the other trim packages?
  19. Feb 25, 2017 at 3:28 PM
    #299
    grynblk
    grynblk New Member
    2017 Black Tacoma TRD Off Road
    I'm new here but just bought a 2017 Tacoma. I've read reports of the LED lights causing electrical issues in the 2016 models. Has anyone had issues in their 2017 trucks after switching? I don't want to invest in LED lights if it'll mess up my truck. Thanks!
  20. Feb 28, 2017 at 3:58 AM
    #300
    DJ TonyT
    DJ TonyT 2017 TRD 4x4 Off Road DCSB - Sunroof and JBL
    TonyT
    Jacksonville, FL
    I have the same question - does anyone know?
