LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016+)' started by chan2565, Jun 14, 2016.
  1. Jan 5, 2019 at 1:14 PM
    #3941
    IPNPULZ
    IPNPULZ Well-Known Member
    Somewhere in time.....
    2017 TRD Off-Road Super White....
    Leer 700 series Tonneau,Bedrug,tinted windows,Weather Tech floor mats
    So now that this has happened with Hikaris on low beams what should i use a High beams?
    RobP62 likes this.
  2. Jan 5, 2019 at 1:50 PM
    #3942
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    So you contacted the Amazon seller and they are not going to send you a coupon for a replacement bulb?
  3. Jan 5, 2019 at 1:52 PM
    #3943
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
  4. Jan 5, 2019 at 2:01 PM
    #3944
    IPNPULZ
    I sent them an email but have yet to hear back im sure they will take care of it. I just put my old headlights back in. I was going to buy Hikaris for the high beams but I am having 2nd thoughts now so now I need to look around for a HB replacement. I will want them to replace the pair!
    RobP62 likes this.
  5. Jan 5, 2019 at 2:12 PM
    #3945
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    Ahh, ok. Well, I know some people are not keen on endorsements but I like my @XenonDepot Extreme Pro LEDs. At least if you have an issue you can call and speak to a person who is also an end user.
    And then there's @deAutoLED.com . I mean, I have their bulbs too in my front turn signals. They are insanely bright. And they also have excellent customer support.
    Pick one, either will not be a bad choice.
    I will only buy lighting from sources that offer customer support from now on.
    Case in point. My 42" Auxbeam lightbar developed a crack in the clear lens. Maybe stress related, maybe a stone. Ou was prepared to attempt a repair but I contacted them. It was within the warranty time frame so they sent a new light bar.
    I am a Amazon Prime member and shop there nearly daily but I definitely think twice about what I buy. Lighting, unless it's through the manufacturer will not be one.
    Parker315 likes this.
  6. Jan 5, 2019 at 2:24 PM
    #3946
    IPNPULZ
    I really want to look into the xtreme pro led lights.
    Parker315 and RobP62 like this.
  7. Jan 5, 2019 at 2:40 PM
    #3947
    NEPAChuy
    NEPAChuy Active Member
    Jeremy
    2018 Tacoma TRD OR Blue Pearl
    Those photos do the products much better justice and they look great! Nice work. I never said they looked poor.
    The only more impressive finish I've seen personally was a filled, sanded, and airbrushed piece, which is a lot of post-processing that would drive up cost substantially.
    ToyoDrew and RobP62 like this.
  8. Jan 5, 2019 at 2:43 PM
    #3948
    NEPAChuy
    Jeremy
    This is why I've gone with deAutoLED bulbs for my truck. I read most of this thread prior to purchasing and the general consensus was great quality and customer service. My truck just seems to not get along with the bulbs and I can't figure out why. And I'm 99% certain it isn't user error. How many engineers does it take to "screw" in a light bulb?
  9. Jan 5, 2019 at 2:55 PM
    #3949
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    On the @XenonDepot website there is a 10% off coupon. You might get free shipping too. Would make them $108.
  10. Jan 5, 2019 at 2:56 PM
    #3950
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    Now you know why I suggested @mesojdm :thumbsup:
  11. Jan 6, 2019 at 7:33 PM
    #3951
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    any updated lists on interior LEDs? from the pages i could find, quite a few different ones that "worked" or did not fit right...
  12. Jan 8, 2019 at 9:19 AM
    #3952
    VE7OSR
    VE7OSR 'interfering with Natural Selection since 1990'
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You will be dissapointed by the inexpensive Ebay dual color. They are only 3.6Watts each.
    https://youtu.be/OiepB7FL6Sw
    Parker315, KingRob and RobP62 like this.
  13. Jan 8, 2019 at 9:25 AM
    #3953
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    Great vid! A clear example of you get what you pay for in this case. That's why I don't mind spending the extra money for better lighting when I have to.
    However, there are exceptions to this rule and every once and while you spend less and get the same as people spending more. My light bars are like that.
    Parker315 and KingRob like this.
  14. Jan 8, 2019 at 11:01 PM
    #3954
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Ebay model, you take your chances. Dual color, good output, though no strobe functions, or combined color output. just switchable between 3000K (yellow) and 6000K (white) colors.
    https://www.ebay.com/itm/2X-dual-co...4-9005-9006-9007-9012-880-9000LM/142871179541
    36Watt , fan cooled, though raw lumen output is exaggerated, as are most of these type of ads.
    Realistically, an educated guess you are likely to get about 1800 - 2000 Lumen per bulb, and this should be a considerable improvement over stock, pending the beam pattern. If used in a projector it should work quite well; Reflector housing its a gamble on if you will have glare, or unwelcome shadows. Overall the design of this bulb is good with its thin center point, getting the light source as close as possible to stock filament location in the one axis.
  15. Jan 9, 2019 at 6:10 PM
    #3955
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Opinions please on the following :
    1.) Headlight Revolution GTR LED
    2.) Headlight Revolution Supernova V4
    3.) Xenon Depot Extreme Pro LED
    4.) Other ?
    Thanks
    RobP62 likes this.
  16. Jan 10, 2019 at 4:12 AM
    #3956
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    Don't waste your money on #1 buy #3 instead. Easy choice.
    Edit - check out the link in my signature.
  17. Jan 10, 2019 at 5:58 AM
    #3957
    IPNPULZ
    Once I get this burnt out bulb replaced. I diffidently wont be buying Hikari's ever again.....
    RobP62 likes this.
  18. Jan 10, 2019 at 6:37 AM
    #3958
    SLACKBOY
    Erich
    Washington State
    Thanks for the feedback !
    RobP62 likes this.
  19. Jan 10, 2019 at 7:51 AM
    #3959
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    So are they sending you another one?
  20. Jan 10, 2019 at 7:51 AM
    #3960
    RobP62
    RobP62 DCLBMAFIA
    Rob
    Street, Md.
    TTC Member #0125
    You're welcome.
