LED lighting on door locks....!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mizicko705, Oct 31, 2011.
  1. May 18, 2014 at 6:36 PM
    #161
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Works now! My doors weren't fully closed it turns out which somehow cancelled out my ability to lock the doors
  2. May 18, 2014 at 6:39 PM
    #162
    I8AJEEP
    I8AJEEP Dynamite Design Josh
    Josh
    Lexington NC
    05 DC TRD SAS
    SAS, with tons, 3linked front and rear…I stopped saving receipts for my sanity
    good clean work I like it a lot
  3. May 18, 2014 at 6:44 PM
    #163
    MTopp
    05 SR5 4x4
    Mine is not as clean, but I had gone too far to turn around so had to keep goin. Tip: go slow, step back from your trimming and drilling often to check how it fits or not
  4. May 18, 2014 at 6:49 PM
    #164
    BLKoutTacoma
    BLKoutTacoma Well-Known Member
    Adam
    OHIO
    08 SR5 Custom badged
    awesome custom thread this is cool!!
  5. Sep 10, 2014 at 9:11 AM
    #165
    Tacoma fire
    Tacoma fire Active Member
    Michael
    Alabama
    13 PreRunner
    Transition back up image from mirror to touchscreen radio!
    Hey I cant find your Mod for the led door lock mod...
  6. Sep 10, 2014 at 9:14 AM
    #166
    MTopp
    05 SR5 4x4
    Mine? It's in my build page I'm pretty sure
  7. Sep 10, 2014 at 9:36 AM
    #167
    Tacoma fire
    Michael
    Alabama
    13 PreRunner
    I got it thanks!
  8. Sep 10, 2014 at 9:37 AM
    #168
    MTopp
    05 SR5 4x4
    Cool man. Now I want them to be white though, uggghhh, maybe take it apart and redo
  9. Sep 10, 2014 at 11:06 AM
    #169
    packrobottom
    packrobottom Well-Known Member
    Pack
    Sky Silver SR5 DC v6 with sport mods
    I think tapping into dimmer circuit would be better. on when doors unlocked off when locked. fade in and out too.
  10. Sep 10, 2014 at 12:53 PM
    #170
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Sub for this thread...
    If OP is still around... where did you get the Plexiglass? Would JB Weld work to hold the LED in? Was thinking a bicolor LED setup, red when locked (triggered by a switch).
    Lots of ideas churning because of this thread! :) :)
  11. Sep 10, 2014 at 3:28 PM
    #171
    MTopp
    05 SR5 4x4
    Just use an epoxy or hot glue. For me, jb is too permanent, if one goes out or you want another color, would have to remove jb. Dimmer circuit would be best, but I already had many other interior LEDs wired to my fuse tap that goes on with parking lights
  12. Sep 12, 2014 at 9:06 AM
    #172
    mizicko705
    mizicko705 [OP] Im that one guy!!! Who did that one thing...
    Kevin
    Socal
    05 Prerunner TRD V6
    (2) 12" rocksford Fosgate P3SD412 1000 watts RMS Sony explode deck Tinted Windows Blacked out Emblems Black hood scoop, valince bar and sleeved fog lights. FlowMaster 40 series BHLM Head lights Led lit door locks
    im still very much around :D haha. I got the plexiglass from home depot they carry small sheets for like $2 more then enough to get the job done! And jb weld will work but clear silicon is best as it wont make it look discolored behind the plexiglass>:D
  13. Sep 12, 2014 at 9:29 AM
    #173
    MTopp
    05 SR5 4x4
    Yeah, if I redo it, I'm going to use silicone.
  14. Sep 12, 2014 at 2:28 PM
    #174
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    still need to do this.... i have the parts.. just need to tackle it
    if i use the add-a-fuse feature and tap into the parking lights, how much power does my fuse need to be? I'll be running this and bed lights.
  15. Sep 12, 2014 at 2:38 PM
    #175
    MTopp
    05 SR5 4x4
    So the door lock LEDs and bed lights on that fuse tap? Well, you could add all the amps of each LED/LED strip and then convert to whatever the fuse are in, what is it watts? My brain is not thinking of it right now. Otherwise a number 2 or 3 watt/amp fuse should be fine. Just remember the original fuse goes over the original slot and the new fuse that goes to LEDs goes on the side slot
    Edit: fuses are in amps I'm pretty sure. So convert whatever power requirements for all LEDs to amps
  16. Jun 7, 2015 at 4:03 PM
    #176
    MTopp
    05 SR5 4x4
    Cool beans
  17. Aug 13, 2015 at 8:52 PM
    #177
    mizicko705
    Kevin
    Socal
    05 Prerunner TRD V6
    Anybody tried this yet, I'm curious to see pictures of there are any.
  18. Aug 13, 2015 at 9:08 PM
    #178
    MTopp
    05 SR5 4x4
    Other than me, I do not know haha. I need to redo mine soon, still haven't got to it
  19. Aug 14, 2016 at 7:17 AM
    #179
    Nitsud
    Nitsud Well-Known Member
    Dustin
    2007 White Tacoma 4x4 Double Cab TRD Off-Road
    This post is a bit old, but the MOD is sick! Definitely sub'd
    Sugar Silva likes this.
  20. Dec 5, 2016 at 11:55 AM
    #180
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Interesting i like your idea man good stuff. Now you got me thinking.......
