LED Lighting Strips (Interior/Exterior)
Discussion in 'Group Buys' started by Drunknsloth, Mar 14, 2011.
Thread Status:
Not open for further replies.
  1. Mar 18, 2011 at 12:50 PM
    #41
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Yep, 3M molding tape is what I'm going to use when I get a couple more bars.
  2. Mar 18, 2011 at 1:40 PM
    #42
    2K6 Taco
    2K6 Taco Well-Known Member
    Philly
    06 TRD Sport D-Cab LG Bed
    Any pics of the connectors?
  3. Mar 18, 2011 at 9:28 PM
    #43
    Drunknsloth
    Retribution
    South West
    Sorry for the delay, but here they are:
    The connector from the Rigid Bars to 12v and Ground:
    The connector between two bars to extend the bars or turn the position of mounting (various lengths 1', 5', and 20'):
    Two bars connected directly:
  4. Mar 18, 2011 at 9:47 PM
    #44
    Drunknsloth
    Retribution
    South West
    Added to OP:
    SET PRICES FOR INDIVIDUAL PURCHASE:
    - Pair of Rigid LED Bars: $29.98
    - 12" Flex Strip: $15.99
    - 1' Connector for Rigid LED Bar: $6.99
    - 5' Connector for Rigid LED Bar: $8.99
    - 20' Connector for Rigid LED Bar: $14.99
    (Still trying to put together a set package)
    I also changed some minor details to give more information.
  5. Mar 19, 2011 at 6:18 AM
    #45
    lancezimm
    lancezimm Active Member
    Lance
    Castle Rock, CO
    '06 Tacoma TRD Off Road
    Kenwood KDC-BT645U headunit w/ Metra Dash Kit and Axxess ASWC, Access Roll-Up Tonneau, Pop-N-Lock Tailgate Lock, WeatherTech Floor Liners, Wet Okole Seat Covers, TRD Cold Air Intake, Toyota Running Boards, Toyota Mudflaps, Toyota Bug Shield and Toyota Bed Mat
    Retribution, thanks for the reply on the 3M tape process. Are you going to include a connector with a positive and ground wire with each rigid light bar? So, two connectors and two rigid light bars for $29.99.
    Also, to waterproof, I assume we'd need to fill the female end of each light bar full of silicone as well as around the connector. Is that accurate?
  6. Mar 19, 2011 at 6:55 AM
    #46
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    Subscribed
  7. Mar 19, 2011 at 9:40 AM
    #47
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    alright i think i am going to change my order, i am going to get 2 pairs(4 total) of rigid bars, 2 power/ground conectors, and 2 1' conectors. I dont know if the if you are going to include a power/ground conector for every bar but if so, instead of getting 4 and paying for the 2 1' conectors can you just substitute the conectors and not have to pay for them?
  8. Mar 19, 2011 at 11:46 AM
    #48
    06TRDZombieHunter
    06TRDZombieHunter Well-Known Member
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    K&N Intake System Port and Polish of TB x2 E3 Diamondfire Sparkplugs 2.5" Leveling kit 32" BFG A/Ts Zombie Response decals Custom painted grill, trim under headlights, scoop, intake and manifold. No more mud flaps, Temp gauge inside intake box, BHLM, extra D-rings in front of bed, No more plastic storage box behind rear seats. More to come.
    So are these setup for 12v cause in the original pics the LED bar is plugged into a wall socket.. Im looking to put some in the bed. Yours are by far the brightest but I dont know what length to get, or bar vs flexible... I just want regular white color.
    ?? Thank you
  9. Mar 20, 2011 at 8:02 AM
    #49
    2K6 Taco
    Philly
    So to my understanding, the ridgid bar comes witht that black connector with every purchase and the gray connectors are optional?
  10. Mar 20, 2011 at 8:40 AM
    #50
    deerdevil
    deerdevil Member
    Jeremiah
    South Texas
    ARB Replacement Front Bumper, leather interior, painted front emblem black,
    Subscribed
  11. Mar 20, 2011 at 10:07 AM
    #51
    Drunknsloth
    Retribution
    South West
    I just talked to my uncle. The connectors are not included in the light bars' price. We are only selling the bar to bar connectors in which you can cut off the male end and take the wires to connect it to the 12v source and ground. This is so you can choose the length of wire that you want.
    Correct
    So for your set up you can get 4 connectors and cut two male ends off so your set up would look like:
    Fusebox----Connector----LED----Connector----LED
    For the bedlights, personally I think the rigid bars would be more durable if something accidentally hits it or something. They are 12v, the wall socket is plugged to a AC to DC convertor box and then to my LEDs.
    My uncle just informed me that it does not come with the black connector because we are offering the other connectors at different lengths so you can just cut off the male end and connect it to the power source and to ground.
  12. Mar 20, 2011 at 1:07 PM
    #52
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I'd be interested in a pair of rigid bars. Essentially, I want to put one on each side of the bed rails. So I take it I would need the "pair of rigid bars" and 2x 1' connectors (cutting the male ends off to run power?)
    When are these able to be shipped out? s/h options?
  13. Mar 21, 2011 at 9:15 AM
    #53
    espdtrd08
    espdtrd08 espdtrd12
    Virginia
    2012 4runner w/ kdss
    Icon lift, 285 duratracs, shrockworks sliders, weathertechs, leds throughout, Gobi rack w/ladder, rigid driving fog lights, trd shift knob for extra hp, MGM hood vinyl wrap
  14. Mar 21, 2011 at 2:07 PM
    #54
    Drunknsloth
    Retribution
    South West
    That is correct I'll put you on.
    I'm talking to my uncle tonight to get the final details. We should be shipping out very soon.:D
  15. Mar 21, 2011 at 8:10 PM
    #55
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    subscribed...
  16. Mar 21, 2011 at 9:56 PM
    #56
    Drunknsloth
    Retribution
    South West
    UPDATE:
    -The flexible strips might include built in molding tape with a price increase.
    -I am getting connectors similar to this picture with ~2 meters of wire in the next couple weeks. Price will be similar to the connectors from bar to bar. Change your order by posting on here or PMing me if you want these:
    -We will be finalizing payment methods in the next week and shipping out COOL WHITE RIGID BARS in the next couple weeks!!!
  17. Mar 21, 2011 at 11:01 PM
    #57
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    OP, I'ma gonna want some for bed lights and maybe hood lights too. But, I gotta figure out what connectors I need. Maybe you can make suggestions for a set-up? Also, will these light strips interfere with the functionality of the rails? I was thinking flexible light strips for the rails, for a concealed low-profile look, but you only mention rigid bars for the rails. Which do you suggest/prefer for the bed rails?
  18. Mar 22, 2011 at 7:40 AM
    #58
    Drunknsloth
    Retribution
    South West
    For the hood lights, you can get a pair of rigid bars, a 1' Connector and a 12v/ground connector. Depending on how many lights you want in the bed you can get either 1 or 2 pairs of rigid bars with a 1' connector in between them if you want to spread them out a little and a 12v/ground connector and a 5' connector in between them.
    I am still trying to figure out the details of the connectors of the flexible strips. Both would work fine for bed rails, I would still recommend getting the rigid bars as they would be more protected against impact since they are being used in your bed. I will be shipping out rigid bars sooner then the flexible strips.
    To answer your other question, as long as none of your bed rail accessories rub along the bottom of the rail mounting them under it would not affect the functionality.
  19. Mar 22, 2011 at 7:51 AM
    #59
    Drunknsloth
    Retribution
    South West
    I'll change your order according to my updates with the power/ground wires. My uncle wants to sell everything separate so you guys have more flexibility in the options you would like.
  20. Mar 22, 2011 at 7:55 AM
    #60
    Drunknsloth
    Retribution
    South West
    Here's the updated list of buys:
    The List:
    1) Nixinus (1x Pair of Rigid Cool White Bars, 2x 12v/Ground Connectors)
    2) mnudo200827 (2x Pair of Cool White Rigid Bars, 2x 1' Connectors, and 2x 12v/Ground Connectors)
    3) SuthrnTaco07 (5x RGB 12" Flexible Strips With Connectors) [2 Starter Packages, One extra 12" Flexible Strip and 3 extra Connectors]
    4) bjmoose (2x Pair of Cool White Rigid Bars)
    5) dozer711 (2x Pair of Cool White Rigid Bars)
    6) 97yota4wd (5 Cool White 12" Flexible Strips With Connectors) [2 Starter Packages, One extra 12" Flexible Strip and 4 extra Connectors]
    7) Lrgrnr (2 Cool White 12" Flexible Strips With Connectors) [1 Starter Package]
    8) Chris(NJ) (1x Pair of Cool White Rigid Bars and 2x 1' Connectors)
    9) Manlaan (3x Pair of Cool White Rigid Bars, 4x 5' Connectors, and 2x 12v/Ground Connectors)
    Those with names in red be aware that the starter package may be canceled because I might be getting flexible strips with molding tape and waterproof connectors built in with a slight price increase for each strip.
Thread Status:
