Led Pods as turn signals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wootpete, Jan 9, 2020.
  1. Jan 9, 2020 at 8:26 AM
    Wootpete
    Wootpete [OP] New Member
    Pete
    2005 Black Tacoma TRD Prerunner
    So I’m getting a new aftermarket front bumper soon and I want to mount up 4 led pods inside of it - the 2 outer lights as fog lights and the 2 inner as turn signals. My questions is... is it possible to wire up led pods as turn signals and how do I do this?
  2. Jan 9, 2020 at 8:44 AM
    Wootpete
    Pete
    I was planning on putting an amber lens on the pods - do you know if that would dim the light enough? I also have all 4 pods from a roof rack I purchased a few months back but didn’t like the look of them on top. I still want to use the lights though. Any suggestions?
    Also I’m not sure what you mean as the alternative you mentioned. I’m not too experienced with wiring lights.
  3. Jan 9, 2020 at 8:47 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Google is your friend! whatstcp is referring to utilizing regular 4157 led turn signals with this flasher unit to customize turn blinks and light tap options. I saw this flasher a few days ago thanks to a member and find it quite the piece of equipment!
    https://www.diodedynamics.com/smarttap-led-flasher-for-2005-2015-toyota-tacoma.html
  4. Jan 9, 2020 at 9:12 AM
    Muddinfun
    Muddinfun Well-Known Member
    I have the Smarttap flasher and I really like it. The 2 coolest features of it are the departure lighting for walking up to the house and the wig wag hazard flashers.
    And don't buy your LEDs from Autozone, Orielly, etc.
  5. Jan 9, 2020 at 9:21 AM
    Wootpete
    Pete
    Thanks guys I will check this out.
    DG92071 and Muddinfun like this.
  6. Jan 9, 2020 at 10:28 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
  7. Jan 9, 2020 at 5:54 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    I've had good luck with Www.superbrightleds.com
    Muddinfun[QUOTED] likes this.
  8. Jan 9, 2020 at 7:36 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I'm running these for the front signals https://www.amazon.com/gp/product/B07WYRCZ2M/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    These for the rear signals https://www.amazon.com/gp/product/B06XSQWY75/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Paired up with the smart tap relay = win win!
    Muddinfun likes this.
  9. Jan 10, 2020 at 4:35 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Now you've got me interested. How hard is it to get to the flasher unit on the Tacoma?
  10. Jan 10, 2020 at 5:09 AM
    Muddinfun
    Here’s a thread that shows how to install DRL if you don’t have it. That’s not what you want to do, but the procedure is the same. The Smarttap flasher doesn’t work with DRL, so if you have DRL, you have to eliminate the DRL by replacing the 3 way harness with a grey plastic jumper block. 1 more thing. It has recently been discovered that there is a over the counter tow package (not factory installed tow package)wire harness that has a 4 way flasher harness. If your truck has that, you can’t install the Smarttap flasher.
    https://www.tacomaworld.com/threads/05-drl-daytime-running-lights-install-oem.1475/
    To remove the DRL and install the Smart tap flasher, you need the grey plastic jumper block part# 82671-30360. It's available from the dealer for about $8. Your truck has a 3 way harness that goes to 2 spots on the fusebox and to the flasher on the right side of the fusebox. Remove all that and install the LED flasher and the grey plastic jumper block. This will eliminate your DRL.
    Key word for search— dingleberry
  11. Jan 10, 2020 at 5:17 AM
    Too Stroked
    Tom
    Wow, thanks! No quite as easy to get to as I thought, but not terribly difficult. My truck does have DRLs and the factory tow package, so I'll have to get the jumper block.
    Going to have to wait for warmer (and drier) weather if I'm going to install this one. Thanks again!
  12. Jan 10, 2020 at 6:57 AM
    Muddinfun
    @Too Stroked I edited the above post to include the jumper block info.
  13. Jan 12, 2020 at 3:43 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
  14. Jan 12, 2020 at 5:42 PM
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    A week so far and they're nice and bright. I swapped out the oem relay for diode dyanmics smart tap relay so no hyper flashing here.
