Led replacement headlight bulbs
Discussion in 'Lighting' started by Mountaineerfan, Aug 19, 2015.
  1. Aug 25, 2015 at 12:30 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'll see what I can do but the streets around here are pretty well lit.
  2. Aug 27, 2015 at 12:04 AM
    BigE
    BigE Well-Known Member
    Eddie
    PNW
    14 MGM DCLB TRD sport
    check out my build page
  3. Aug 27, 2015 at 12:25 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Stay away from lifetime led! There are multiple problems with them! Also for LED fog lights I use rigid arms and they have worked great without any issues.
  4. Aug 27, 2015 at 12:30 AM
    BigE
    Eddie
    PNW
    Im looking for headlamp replacements.. Any suggestions?
  5. Aug 27, 2015 at 12:40 AM
    MGMTacolover55
    Orygun
    floor Mats
    You should check out opt7 or VLED if you feel brave and want to do an LED rertofit that would be cool.
  6. Aug 27, 2015 at 12:45 AM
    BigE
    Eddie
    PNW
    When you say LED retrofit, you mean do a projector retrofit and add LED bulbs?
  7. Aug 27, 2015 at 12:47 AM
    MGMTacolover55
    Orygun
    floor Mats
    I mean take an LED light meant for a jeep with the round housing and put it in the tacoma headlight housing.
  8. Aug 27, 2015 at 12:52 AM
    BigE
    Eddie
    PNW
    Yea..... I'll let the mad scientists try that first..:) I first want to try the Plug n' Play route first. Then maybe move on to a projector retrofit.. Just debating whether I should first drop $$ into the LED's or just dive straight into the retros..
  9. Aug 27, 2015 at 5:53 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I'll echo this.
  10. Aug 27, 2015 at 2:13 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    I am using the Bright Ass Led drop in kit for the past 5 months and no problems what so ever !
  11. Aug 27, 2015 at 2:29 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Go on Amazon.com and get opt7 led bulbs, bright as hell and I love em!!! Had 360 lighting (brand) and they were nothing compared to these. They have tiny ballasts which is a win! Only thing is you have to take the silver locking tray off with a small Phillips screwdriver, put the boot over the bulb, then put the tray back on. Took me 10 minutes to install. $00.02
  12. Aug 27, 2015 at 4:19 PM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    You guys have pics by chance?
  13. Aug 27, 2015 at 6:44 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    Another thing is with the led lights, a "retrofit" projector lens comes with the xenon bulb built in. You cannot use a preexisting bulb. If there is a retrofit projector lens that uses our stock bulb, I will buy it right now.
  14. Aug 27, 2015 at 6:46 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    The light is a blueish white, you will not be disappointed. I can snap pics of what I did if you want to know. The ones I bought were red with 4 LEDs per bulb. 2 lo 4 HI, bought em cause they were the colour of my taco. Could not be happier. Take it on faith for now
  15. Aug 27, 2015 at 6:47 PM
    #35
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Yeah I'm hoping it's a tighter spill as opposed to just throwing an HID bulb in there with no projector I heard the split LEDs help stop that.
  16. Aug 27, 2015 at 6:53 PM
    #36
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    Yeah the LED I had on my old truck (ranger) was split, top row for lo and bottom and top for HI, so it would light only the top half of the lens on lo, was cool for a bit then looks weird once you stop loving them. These ones have a better design, if you don't want split bulbs there are ones by CREE that I know nothing about besides that they have leds all around the "bulb"
  17. Aug 28, 2015 at 12:02 AM
    #37
    snowbrdd
    snowbrdd Well-Known Member
    Get Philips X-Treme Vision bulbs. Or any other higher power halogen bulb from Philips, Osram, or Sylvania. That's the only way to ensure proper light pattern. No LED bulb will guarantee a proper light pattern. Also, whiter =/= brighter.
    If you're having problems seeing in bad weather, Rigid LED foglights + lower speed are your best option. No amount of light will help you drive safely at higher speeds in bad weather.
  18. Aug 28, 2015 at 12:41 PM
    #38
    Dr. Jekyll
    Jimmy
    Honolulu, HI
  19. Sep 2, 2015 at 9:58 PM
    #39
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    I have used both Lifetime and VLED and ended up sending my Lifetimes back because I was not at all happy with them.
    VLED puts out a top tier product. I had Factory LED Headlights in a 2014 Rogue I was driving and far and away they are the best headlights I have ever used and I drove through some pretty dark mountain passes and roads with them, I am hooked on LED's now.
    LED is the way of the future IMHO, I am disappointed that Toyota will not be putting them in the 2016 Taco to match the LED DRL's. The projector halogens they are using seem to have mixed reviews...
    If you go with the VLED's go with the 5000K because the 6000K's have a slight Blue Tinge to the Light Colour.
    I put 5000K VLED Fogs in my Rogue to match the Factory LED Headlights and they were a perfect match, the Factory Halogen Fogs that I swapped out with the VLED LED's looked yellow next to the LED Headlights.
    One thing I am going to do is see whether I can swap the Projector Halogens with the LED's in the new 2016 Taco, but it might be a challenge.
  20. Sep 3, 2015 at 7:43 AM
    #40
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    http://smile.amazon.com/dp/B00VNBEJ1G/ref=sr_ph?ie=UTF8&qid=1441291126&sr=1&keywords=opt7+led+h4
    This link are the ones I have, the link is smile.Amazon.com to donate a small proceed to charities for free! But they are phenomenal, they are bright, give a nice spread of light on the road, and have wicked range. 100% improvement over the OEM. I have run nighthawks as well and these knock any traditional halogen bulb out of the water. Ask me about installation of LED headlights. You should be able to figure it out but I got the trick.
