LED Tail lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by A/C Mech, Jun 3, 2019.
  1. Jun 3, 2019 at 10:21 PM
    A/C Mech
    A/C Mech [OP] Well-Known Member
    Alan
    LBC
    2017 TRD OFF-ROAD
  2. Jun 3, 2019 at 11:21 PM
    Roxanne16
    Roxanne16 Well-Known Member
    Zack
    Kansas City, MO
    2016 Magnetic Gray Tacoma Limited (Roxanne)
    2000 Toyota Sienna 2004 Toyota Tacoma 2001 Acura Integra LS 1999 Toyota Celica 1998 Toyota Harrier (Lexus RX300) 1999 Toyota MR-S 1999 Toyota Altezza (Lexus IS300) 2016 Toyota Tacoma Limited MGM
    If you have one side stock halogen, and the other led, does the LED work?
  3. Jun 4, 2019 at 8:17 AM
    A/C Mech
    Alan
    LBC
    2017 TRD OFF-ROAD
    Sorry had to edit my problem. Forgot to add the issue is the brake lights. They work when the running lights are off. When the running lights are on they don’t. Seems as if they are “single” LED’s.
    The description said they would work as tail/brake lights.
  4. Jun 4, 2019 at 8:18 AM
    A/C Mech
    Alan
    LBC
    2017 TRD OFF-ROAD
    I’m gonna check right now.
    Thanks
  5. Jun 4, 2019 at 8:23 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    Are the "running lights" really bright? Like brake light bright? If so, they may be (for some reason) backwards.
    If that is the case, then your running lights are using the "brake" brightness, and when you press the brakes the "running light" brightness is triggered, but is not visible because it's already putting out the brighter "brake" light. Does that make sense?
    I am not sure how that would be possible, but that's a scenario that would explain the symptoms you described.
  6. Jun 4, 2019 at 9:41 AM
    A/C Mech
    Alan
    LBC
    2017 TRD OFF-ROAD
    That’s kinda what it seems like...
    Because I just checked them in the daylight and it seems like they work fine. At night you can not notice them. How the hell did that happen!? All I did was plug in some LEDs in place of the halogen bulbs...
    These LED’s are kinda a pain in the ass...
    Had to install those resistors in the turn signal lights...
    Probably should of just left it all OEM!
    Tullie D likes this.
  7. Jun 4, 2019 at 11:00 AM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
  8. Jun 4, 2019 at 11:02 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Yes!!!!!!!!
  9. Jun 5, 2019 at 3:17 PM
    A/C Mech
    Alan
    LBC
    2017 TRD OFF-ROAD
    Roxanne16 likes this.
