LED tailgate strip- HELP!!!
Discussion in 'Lighting' started by 09toyotacoma, Jun 15, 2010.
  1. Jun 15, 2010 at 1:17 PM
    09toyotacoma
    09toyotacoma [OP] Active Member
    NY
    09 4cyl 5spd 4x4 access cab
    I bought a street glow optx 49" tailgate strip (red led lights that mount under the tailgate) and im having trouble wiring it. I dont have a trailer wiring harness so I am going to hard wire it like the directions say. I kind of understand what to do, but there are so many wires running to each taillight and some of them are the same color. I need to figure out which wire to attach the left turn signal to, the right turn signal, the running lights, and the ground. All the wires are wraped in the black plastic so I cant follow them. Has anyone had these issues or can anyone help me?
    Thanks, Mike
  2. Jun 15, 2010 at 1:43 PM
    CVR6
    CVR6 Active Member
    Never fished around back there yet... I recommend picking up a volt meter, they are cheap and indispensable when searching and properly wiring. Harbor freight usually has them for a few bucks.
  3. Jun 15, 2010 at 1:46 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Get a multimeter, voltmeter, or a test light.
  4. Jun 15, 2010 at 1:51 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    test light will work fine
  5. Jun 15, 2010 at 2:06 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    you could also try tugging on the wire. when you see it move thats the one your pulling on. if the wire does not have sufficient slack i would not recommend this
  6. Jun 15, 2010 at 6:40 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Scroll to nearly the bottom of the page. The wiring diagrams oughta help.
  7. Jun 15, 2010 at 7:08 PM
    lifespan1
    lifespan1 New Member
    Roger
    Rhode Island
    02 Tacoma SR5
    Mike, get yourself a wire tracer probe. Looks like a small piercing tip screw driver with a 24" wire attached to an alligator clip. There's usually a bulb or LED in the handle. With someone in the cab pressing the brake peddle, attach the alligator clip to chassis ground and pierce the individual wires by the back bumper. Whichever one lights is your brake light power source. Attach your light strip to this wire and ground the other and you should be set to go. Good luck....
  8. Jun 17, 2010 at 2:13 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    just something ive noticed. 9 out of 10 led strips i see on trucks dont work properly, they are either half working or blinking or one side will half half power, etc...
    just be carefull splicing wires if your gonna have to take this thing off sooner than you think.
    Dont get me wrong, I like the looks of them but I wouldnt get one from what I've seen on their quality
  9. Jun 17, 2010 at 2:19 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Here are the wire colors.
    Tail Light (Running Light)
    + Green
    Brake Light
    + Blue
    Left Turn Signal
    + Blue/Black
    Right Turn Signal
    + Blue/Yellow
    ...And the Black/White is your Negative (ground)
    Also.
    X2.
