LED Tape Bed Illumination
Discussion in 'Lighting' started by mikedaddy, Apr 5, 2012.
  1. Apr 5, 2012 at 5:28 PM
    mikedaddy
    mikedaddy [OP] Active Member
    Jacksonville, FL
    2012 Tacoma Double 4x4
    Super easy to do! Bought 16ft of waterproof LED tape off of Amazon for 12 bucks and a few parts from an auto parts store. Ran the tape under the bed rails and put the switch in the bed. I am trying to hunt down a switch that is lit when the lights are off and off when the lights are on so I can find it easier in the dark.
  2. Jul 31, 2012 at 8:15 AM
    12DblCab
    12DblCab I don't know what to write here
    South
    2012 DCSB TRD Sport "Pyrite Mica"
    Can you post a link to what you bought? I'm looking at some on Amazon, but I can't tell if they are going to be bright enough. I looked at some LED strips at Autozone that had a TEST button, and they were either weak or flashed in a sequence.
  3. Aug 1, 2012 at 1:29 AM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    More info and pics of your install please
  4. Aug 1, 2012 at 9:15 AM
    12DblCab
    South
    I was looking at this set on Amazon. It looks like it is waterproof, has an adhesive backing, and should be long enough to go around the 3 walls of the bed on a short bed Tacoma. I think this is pretty much the same set the OP bought.
    http://www.amazon.com/NEEWER%C2%AE-Intensity-300-Flexible-Superbright/dp/B005ONEJ00/ref=cm_cr_pr_product_top
    I'm not sure what kind of wiring setup I would need to run it straight to the battery. :eek: An inline fuse and what else? What size fuse?
  5. Aug 1, 2012 at 3:44 PM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I have a couple of lights in my bed right now with an inline fuse ran straight to the battery. I want to go to LED lights
  6. Aug 6, 2012 at 5:32 PM
    RipVanDango
    RipVanDango Active Member
    Cody
    Alaska
    '92 / 2012 TX Pro
    Leer 100XL Canopy, Home Made LED Bar, Lightforce Blitz 4300k 35W HIDs, Supertones Hella Horns, LED Bed Light,
    I have strips of LEDs under the rails in my truck. I used the silicone coated ones from superbrightleds.com. Ran a switch out of the enclosure next to the ac outlet, and ran that to an inline fuse at the fuse box/battery terminal, ran a single wire up the right side of the frame following the existing wiring harness as far as it went. They aren't that bright in the day, but camping I can't sleep with them on. It's like closing your eyes while looking at the sun, bright! They have watertight ends and watertight connects that are pretty cheap. It was more than 12 dollars, but it works really well. I adhered them with a simple tube of silicone from lowes, since they are silicone, and they are stuck on tight.
  7. Aug 6, 2012 at 5:33 PM
    RipVanDango
    Cody
    Alaska
    '92 / 2012 TX Pro
    5 amp fuse should work fine, 10 is plenty.
  8. Aug 19, 2012 at 7:44 PM
    PhantomVirus
    PhantomVirus Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    12Dbl
    Did you pull the trigger and buy them? Really debating these - need them to be bright enough and low profile enough.
    However, they are cheap enough to be throw away if needed but I really want then to work well ;-)
    Take a look @ this wiring posting....he tied it into his overhead / console light....
    R
  9. Aug 19, 2012 at 8:52 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop
    Subbing, so I can buy these when I get to a computer. Well done guys.
  10. Aug 19, 2012 at 8:55 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
