LED Turn Signals Bulbs
Discussion in 'Lighting' started by SMG26, Sep 23, 2009.
  1. Sep 23, 2009 at 11:17 AM
    SMG26
    SMG26 [OP] Well-Known Member
    Woodstock,GA
    06 Prerunner TRD Offroad
    Injen CAI, JBA exhaust pipes 2.5" w/magnaflow muffler, Doug Thorley Long tube headers, URD MAF CAL and O2 sim,Access roll up cover, AVS Wind deflectors, coverking seatcovers, grillcraft upper/lower grille, Halo projectors w/6000k HID and pop lock on tailgate.
    I just finished putting in my LED flasher that I got from superbrightleds.com and some bulbs. I turned the truck on and tested to see if the turn signals work. The front signals do not work but the rear signals do. I even tried putting the old 3157 stock bulbs in and they would not even flash. Any help would be great.
  2. Sep 23, 2009 at 11:19 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    You may have a blown fuse. Check the fuse, I believe it's a 5 amp fuse.
  3. Sep 23, 2009 at 11:56 AM
    SMG26
    Woodstock,GA
    Yeah checked all fuses and none are blow any other suggestions
  4. Sep 23, 2009 at 12:02 PM
    SMG26
    Woodstock,GA
    Also I had the DRL jumper and harness in there when I bought the truck would this maybe the problem.
  5. Sep 23, 2009 at 12:03 PM
    Rollinn
    Rollinn Well-Known Member
    Vegas
    06 Prerunner sport
    Icon 2.5 c/o,TC uca, bhlm mod, nav, etc etc
    I had the exact same problem when I went to install led bulbs up front.. They didnto work, I switched back to the stock ones and they worked.. I think they draw a different amount of amperage possibly.. I think if you put ALL the bulbs back to stock they would work again..
    But am unsure of why they wouldnt work..
  6. Sep 27, 2009 at 5:23 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    You have the bulb in backwards. LED's are only polar one way I'm pretty sure.
  7. Sep 27, 2009 at 7:55 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    He stated that even the stock bulbs don't work.
    OP, try looking for a blown fuse.
  8. Sep 27, 2009 at 8:06 PM
    PPD934
    PPD934 Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    I have changed many motorcycles bulbs to led... on all of them I had to install a load equalizer on them in order to get them to flash... you have to be really careful with them though disconnect the battery or you wil burn the equalizer out.....
  9. Sep 30, 2009 at 9:58 PM
    GUNNERGREEN
    GUNNERGREEN Victory through supreme firepower!
    James
    Georgia
    TRD SR5 Double Cab White
    Led's draw alot less amperage than regular bulbs. The flash relay will not function properly due to the loss of amps being pulled. It could possibly damage the relay as well if not carefull. Make sure to add a load equilizer to keep the amperage where it needs to be.
  10. Sep 30, 2009 at 10:35 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Load equalizer? Is this a resistor just to increase the resistance? No savings in amperage there? I guess I should stick with the $2 bulb!
  11. May 6, 2010 at 7:29 AM
    cweeks1934
    cweeks1934 Active Member
    clarence
    South Carolina
    2010 SR5 Prerunner
    I had to put in a 6 ohm 50 Watt Resistor for each bulbs ,,, (RL-650)
    before I could get the LED lights to work right ,,,,
    what is the Flasher no did you get thanks
  12. May 15, 2010 at 1:01 AM
    Hawaiian Taco
    Hawaiian Taco Member
    Pacific Ocean
    TRD Sport Taco
    Plenty
    How are your DRL LEds do they work well? Where did you get the resistor, how did you install, and what are the bulb part numbers??
    Thanks!
  13. Dec 21, 2010 at 10:48 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    hey guys...
    i put LED lights in the signal flashers, switched the flasher relay for a LED relay (to slow the flashing) and now I keep blowing the signal fuse..
    you guys know whats going on?
  14. Feb 27, 2017 at 2:41 PM
    John 14 6
    John 14 6 New Member
    2007 Toyota Tacoma
    Oem blinkers changed to led blinkers
  15. Feb 27, 2017 at 2:44 PM
    John 14 6
    2007 Toyota Tacoma
    Check 15amp fuse in engine well. Turn the cover over see fuse diagram.
