LED turn signals not working in off or DRL switch locatons
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kylewill92, Mar 6, 2024.
  1. Mar 6, 2024 at 9:19 AM
    Kylewill92
    Kylewill92 [OP] New Member
    Kyle
    2020 White Tacoma SR5
    Cold air intake Led lights Decals
    Hello y’all I have an issue! I have a 2020 sr5 and I have swapped all my stock lights to LED’s. Unfortunately whenever the light switch is in off position or DRL my turn signals will blink once and no longer light up, however whenever the switch is in corner marker or headlight position they work just fine. I have switch back LED’s in the front that are supposed to be anti flash along with regular red in the rear, they’re both made by auxito and before installing LED resistors on all 4 turn signals they would blink normally in DRL and off locations but would hyper flash when headlights and corner markers are on. Any help would be appreciated!
  2. Mar 6, 2024 at 11:13 AM
    tacoma warrior
    tacoma warrior Active Member
    2020 Tacoma SR5 silver
    I have a 2020 sr5 and I replaced the low ,high and fog lights with auxito. I don't have any problems, I did not installed led resistor, maybe that is the problem you are having?
  3. Mar 6, 2024 at 11:40 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    SR5 is not immediately ready for LEDs with DRL ... one wire providing power to shared in SR5, 2 wires for dedicated in TRD that has LED DRL. PuppyPunter and daveeasa (use "@" before the name if you want their immediate attention) contributed to this thread which you may want to read first to form targeted questions for the next round: https://www.tacomaworld.com/threads...ed-pod-backlights-with-headlight-drls.826695/
    Chew and musicisevil like this.
  4. Mar 6, 2024 at 11:50 AM
    Niteman
    Niteman New Member
    2023 White Sr5 4 Wheel
    Go to an auto store that stocks or can order a
    led flasher for the year and model of your truck. Worked for my 2006 Tundra when I changed everything out.
  5. Mar 6, 2024 at 5:41 PM
    caribe makaira
    Caribbean, Puerto Rico
    :smack:
    3rd Gen do not have any feature to add a "flasher". It's integrated in the Combination Meter PCB.
    MannyS and Chew like this.
  6. Mar 6, 2024 at 5:47 PM
    ricco333
    ricco333 Active Member
    Erik
    2021 White SR5/4x4
    I have an SR5 and I replaced the DRL with a switchback LED from Amazon and I haven't had any issues. My high and lows are from Lasfit.
    These are the switchbacks I purchased, just in case you want to try.
    Syneticusa 7443 Error Free Dual Color Type 2 Switchback DRL LED Turn Signal Light Bulbs No Hyper Flash Built-in Resistors All in One https://www.amazon.com/dp/B07JFPRFW2
