led turn signals
Discussion in 'Lighting' started by 2013trdgunner, Jul 9, 2015.
  1. Jul 9, 2015 at 4:55 PM
    #61
    2013trdgunner
    2013trdgunner [OP] Active Member
    2013 toyota tacoma black
    3 inch lift hid headlights led marker lights and trd wheels
    It says the fuse is turn&haz fuse no fuse for drl
  2. Jul 9, 2015 at 5:03 PM
    #62
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Sounds familiar. IIRC.. this is misquoted. :p
    Bolts for hwhat?
  3. Jul 9, 2015 at 5:04 PM
    #63
    T4RFTMFW
  4. Jul 9, 2015 at 5:10 PM
    #64
    T4RFTMFW
    Oh my.
    Just you and Mrs Ding on trips?
  5. Jul 9, 2015 at 5:11 PM
    #65
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    i don't know what the change has been made 12+ to wiring... but earlier models have seperate fuses. the parking lamps are on the "tail" fuse. turn signals are on a different fuse.
    DoorDing and T4RFTMFW[QUOTED] like this.
  6. Jul 9, 2015 at 5:13 PM
    #66
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    DRL is controlled by the BCM. early models you had to switch out the relay and a secondary plug/jumper on the BCM. i converted to stock DRL's on my truck years ago.
  7. Jul 9, 2015 at 5:35 PM
    #67
    2013trdgunner
    Got an even bigger problem now only my headlights and break lights work and turn signals even my running lights inside my truck won't come on
  8. Jul 9, 2015 at 5:35 PM
    #68
    2013trdgunner
    And I didn't even do anything
  9. Jul 9, 2015 at 5:37 PM
    #69
    T4RFTMFW
    So what all isn't working?
  10. Jul 9, 2015 at 5:39 PM
    #70
    2013trdgunner
    My drl my regular running lights and my interior lights only thing that works is my headlight brake lights and turn signals
  11. Jul 9, 2015 at 6:07 PM
    #71
    tubesock
    tubesock Well-Known Member
    Id yank the turn signal relay and see what happens. Your turn signals will break, but everything else might start working.
  12. Jul 9, 2015 at 6:18 PM
    #72
    2013trdgunner
    I don't want my turn signals to break
  13. Jul 9, 2015 at 6:21 PM
    #73
    tubesock
    Yes, they will be broken when the relay is removed. But if everything else starts to work then you know you need to replace the relay with a working one. And if removing the relay does not affect anything (other than the turn signals), then put the relay back and you will have determined that the relay is not causing your problems.
  14. Jul 9, 2015 at 6:35 PM
    #74
    2013trdgunner
    I've disconnected the batteries and still nothing
  15. Jul 9, 2015 at 7:39 PM
    #75
    T4RFTMFW
    Try swapping relays.
  16. Jul 9, 2015 at 8:20 PM
    #76
    T4RFTMFW
  17. Jul 9, 2015 at 8:27 PM
    #77
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  18. Jul 9, 2015 at 8:34 PM
    #78
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Gotta admire the mods on this one.
  19. Jul 9, 2015 at 9:27 PM
    #79
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    :ohsnap::rofl::rofl:
  20. Jul 9, 2015 at 9:27 PM
    #80
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
