left lean
Discussion in '1st Gen. Tacomas (1995-2004)' started by beeztlytlr, Dec 29, 2007.
  1. Dec 29, 2007 at 6:02 PM
    beeztlytlr
    beeztlytlr [OP] Member
    Fernley Nevada
    Purple $$$ Eater
    1.5" Shackles in back, Bilstein 5100's front and rear(plus 2.5" in front) BeCool 3000cfm electric fan. Summit Racing 100w off road lights, Doug Thourley Header, Luk clutch, "custom" cat, TRD Coils, JC Whitney leaves.
    I replaced my leaves, coils, struts and shocks and my taco still leans to the left. Every other 95-96 I've seen is the same. Is this normal or is it maybe my canter?
  2. Dec 29, 2007 at 6:50 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Measure the frame from ground up and then measure the body from ground up. I bet it is the body that needs work.
  3. Dec 29, 2007 at 10:44 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah bushings go bad easy to replace
  4. Dec 29, 2007 at 11:18 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    It's called the infamous 1st gen. Taco lean and it's quite common. Three things that make the Taco lean to the left (driver's side) is 1) battery is located on that side 2) so is the driver and finally 3) and so is the gas tank. All of these things contribute to the Taco lean, it's normal.
  5. Dec 29, 2007 at 11:37 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    my 2nd generation taco leans left and i was told it was cuz the gas tank.. and by the way, now is as good of time to ask as any....
    why do we call these taco's 1st and 2nd generation? as if there are only 2??? there are several generations of tacos....
    thanks
  6. Dec 29, 2007 at 11:42 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yeah, there are technically more than 2 gens of Tacos. I see them currently as 4 distinct generations: 95.5-97, 98-00, 01-04 and 05+. But the TacomaWorld.com gods only see 2 gens of Tacos.
  7. Dec 30, 2007 at 7:00 AM
    concrete jedi
    Rochester N.Y
    SHHH you'll wake the Gods, and that is NEVER good, now go sacrifice a virgin or something. :devil:
    FracturedSurfer likes this.
  8. Dec 30, 2007 at 8:17 AM
    beeztlytlr
    Fernley Nevada
    Purple $$$ Eater
    Looks like I'm putting my hi-lift, pioneer set and jerry cans on the right side.
  9. Dec 30, 2007 at 8:38 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Or you can find a fat chick to ride with you as a passenger... :devil:
    Oooops, did I say that? :eek:
  10. Dec 30, 2007 at 12:39 PM
    350TacoZilla
    Hancock MD
    ok there is only two gens of taco...there were face lifts...but I can put an 04 taco front on my 96 or a 00 door on a 04 or etc.. the motors stayed same...trans stayed...axles...frame.... you can put a 04 reg cab cab on a 96 frame and never know difference..... try putting oh say ANYTHING except your wheels off a 05-07 on a 95.5-04 2 gens ... ...sorry to jack thread...as for lean yeah I see it alot and they should have made a heavier rate spring for drivers side... not only is the weight there but how often is it only the driver not 2-4 people in truck... lot of miles are probably with one person sitting in there...maybe put a V6 coil on your drivers side LOL
  11. Dec 30, 2007 at 4:38 PM
    L_Jackson
    Houston, TX
    zilla,
    thanks for clearing up the 1st and 2nd gen question!!! that has bugged me since i joined!!!!
  12. Dec 30, 2007 at 9:26 PM
    350TacoZilla
    Hancock MD
    lol yeah buddy of mine always used to get me going... like yeah i got a 3rd gen taco...man they are so much nicer blah blah blah he had a 01 extra cab v6 trd....i was like oh whats so much better ( i had 96 extra cab with trd super 3" lift 33's lockright locker front and back) oh man the trd locker is sweet... I'm like yeah mine is locked in 2wd 4lo or 4hi ok....oh man the motor is so much better than the old ones....hmmm ok same v6 only mines charged.....and you paid what like $5000 more for yours??? dont see the great deal.... other than white face gauges..he had me there lol .. I love all tacos... I'm not a big fan of the 2nd gens on the simple fact they are bigger than i would want a taco to be..they are like 1st gen tundra size lol.. but otherwise great truck ..
  13. Dec 31, 2007 at 6:29 AM
    L_Jackson
    Houston, TX
    yeah, they are a little big. in one way that is what i like about t hem, in another way i like older models that were smaller.... but i had a 98 dodge ram, so i like the room in a bigger truck.... like anything else i guess, pros and cons.
  14. Aug 3, 2016 at 5:28 PM
    Artycard
    Artycard New Member
    Do you still get taco lean on the 3rd generation lifts? and if i got OME 885 coils and put them on TRD stock struts is it going to be a rough ride?
    -TYIA
  15. Aug 4, 2016 at 3:03 AM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    They did. Check part #'s
