Let’s Talk Tunes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlessdApparel1, Feb 6, 2023.
  1. Feb 6, 2023 at 5:15 PM
    BlessdApparel1
    BlessdApparel1 [OP] Overland Warehouse Online
    Oceanside
    2013 Tacoma Build In Progress
    @pelfreybuilt Aluminum Front Bumper @Dirtking 2.5 Long Travel @bajadesignsofficial Fog Pocket Kit, S1’s, A Pillar Squadrons @bajadesignsofficial 20” S 8 @cbioffroadfab Bedrails @mountain_hatch Tailgate Attachment @dirtylyfewheels 17” Roadkill Race Beadlocks @falkentire Wildpeak A/T’s @yakimaracks RTT @nickdeyatnight Rocksliders And Custom Rear Swingout Bumper @shibui_tank On Board Air @calicowboywhiskey Whiskey @phalcon_trailers Dualzone Fridge @fabzonearmor Skids @Allpro Offroad Bed Stiffners And Gas Tank Skid @archivegarage Rear shock location @Iconvehicledynamics RXT Leafs Pack @4xinnovations hangars and shackle flip @Radflo Custom 2.0 resis with finned 2.5 Res and adjuster
    Well, we all know tunes have been out quite some time for 4Runners and 3rd Gens.
    From what I’ve seen it hasn’t really been since the last year or so that “efficient” tunes have really come out for the 2nd Gen 4.0
    What I wanted to bring up for discussion is the following:
    1. With so many of the average Tacoma owner not knowing anything about mapping and the ins and out of an ecu, is there really a difference on these trucks…
    2: it seems like every few months, a new Company comes out with a new tune or a new name or whatever.
    What tune are you running and why?
    How did you pick that exact company or tuner? Did you have experience with any other tunes?
    3: Lastly, what is the going rate for a tune accords the board.
    Having reheated, intake spacer, and cam gear is there really that big of a difference from a tune?
    share your thoughts, please!
  2. Feb 6, 2023 at 7:33 PM
    TacoTuesday1
    FL
    I too would like to know what tune is best or if pedal commander is best.
    It would be nice to have an actually normal throttle map in the ECU.
    I know in the Audi world you pick big brand reputable names backed by independent shops that have been around for a long time, like APR; but some like GIAC are likely no longer around.
    or after APR came Motoza offering tunes with success, popularity, and customer support.
    Similar probably applies to BMW (Dinan, etc) Benz AMG’s, so on and so forth
    Well established household names
    in the Tacoma world seeing random weird sounding tune names I’ve never heard of, that may not be that popular or have been around a long time, makes me question their legitimacy
    Which is sketchy, for something as important as proper operation of an engine. For one, not being tuned wrong in a way that damages it.
    If you can find a good one, it seems worth it. Probably slightly more power and MPG, better throttle maps
    intake spacer is probably useless. It does not get that hot. Lengthening the intake tract with a spacer increases low end torque by letting incoming air have more momentum. But it probably is already long enough, and with enough momentum, stock. The V6 is also designed from factory to have instant low end torque, whatever small amount it has.
    being a basic, cheap engine, it doesn’t have a lot of power to unlock.
    Anything more than a slight difference would mean forced induction or a different better engine.
  3. Feb 7, 2023 at 12:28 PM
    BlessdApparel1
    Oceanside
    I mean, I’ve heard good things about the KDMaxx tube, but it seems like a year ago, there was some other tune that was “the best”
    And then someone in my area just advertised a Nexus tune.
    It seems like there are so many different options I have no idea where to start.
    i know the pedal commander only fixes the throttle lag, whereas a tune supposedly fixes the shift points, etc
    But hopefully a few other will respond to this to really show and explain their experiences etc.
    i know on a 3rd gen, there is a hell of a difference but idk if I’m convinced in this second gen
  4. Feb 7, 2023 at 6:40 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    PedalCommander isn't an engine tune. All it does is remap the footpedal-to-throttle response curve. A one-trick pony.
    An actual tune adjusts 10s to 100s of individual real-world in-engine paramaters to provide a dyno-measurable increase in power & torque.
    In my opinion this is probably the leading well-known, widely-used, & well-tested Tacoma tune. Available for 2nd & 3rd gens. Suggest reading the entire thread before asking too many questions, they're likely already answered in the thread itself.
    https://www.tacomaworld.com/threads/overland-torque-tune-ott-by-overland-tailor.759590/
    Regarding the disappointed-and-skeptical-sounding comment:
    No, a good tune actually fixes the shift points, at least for 3rd gen auto transmissions. It's not a gimmick, it's legit adjustment of the original factory automatic shifting logic away from Toyota's lame attempt at extracting every last bit of fuel economy, towards normal, sensible, predictable automatic shifts.
    I'm not so sure about 2nd gen auto transmissions. I have a manual transmission anyway, but my understanding from reading TW posts is that the 2nd gen autos don't really need a major overhaul to their automatic gear logic. And/or maybe the 2nd gen ECU just doesn't give the level of fine control over the transmission that the 3rd gen ECU + trans pair does.
  5. Feb 7, 2023 at 6:51 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  6. Feb 13, 2023 at 11:17 AM
    BlessdApparel1
    Oceanside
    I wasn't trying to be Skeptic. Currently there are from what I see, 3 current tunes available for these trucks.
    1. Overland Torque Tune
    2. KDMax Tune
    3. And Lastly, the newly scene Nexus Tune
    From my research it seems like KDMAX is the only tune that has actually shown a Dyno sheet showing the difference in performance from before and after. What I am trying to figure out is ultimately which tune is more beneficial.
    I understand that they essentially are custom EFI and ECU Mappings so they are each going to have differences etc. But with so many "Tuners" in big city area, how does one make the write decision. Generally they cost anywhere from $400-$600 so it would suck to purchase one tune and have a little jump in performance VS another. Just looking for real world experience with the different tunes out
  7. Feb 13, 2023 at 12:25 PM
    GilbertOz
    GilbertOz Driver
    CA
    There are several different dyno test results of OTT (Overland Torque Tune,) for both 2nd gens & 3rd gens. The results start right on the first page of the thread. If you read through the entire thread I believe there are additional updated dyno tests for variant configurations, etc.
    If you care about engine durability I would be extremely cautious about picking a tune based merely on which shows the bigger, badder dyno results. @JustDSM (the primary creator/maintainer of OTT) emphasizes that he has taken great care to ensure that the extra power & torque unlocked by OTT doesn't excessively tax the engine in ways that may significantly shorten its lifetime.
  8. Feb 13, 2023 at 1:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Performance gains on an NA'd 4.0L are minimal (relatively speaking) regardless of tune. What is huge is the drivability gains from the auto transmission side as well as various other things once can change for drivability improvements
  9. Feb 13, 2023 at 1:42 PM
    GilbertOz
    GilbertOz Driver
    CA
    I'm not sure that "minimal" is the right adjective to apply to a 7-10% torque & power gain, consistently across most of the RPM band, on a stock 2nd gen NA 4.0L. I'd say it's $300-$400 very well spent for a well-designed and increasingly-well-tested (by the customer base) no-wrench modification.
    https://www.tacomaworld.com/threads...-ott-by-overland-tailor.759590/#post-27076556 (Scroll down for 2nd gen 4.0L stock/NA dyno results.)
  10. Feb 13, 2023 at 6:26 PM
    nd4spdbh
    SoCal
    on premium fuel. 99% of the users on here dont run premium. I am very VERY well aware of what is capable with HPTuners tune.... hell I was one of the first adopters and quickly became the automatic transmission tune go to guy. Gains CAN be had but pure numbers performance gains are not drastic as some might expect.
    Definitely NOT saying that OTT and JustDSM's tunes are bad, they 100% are amazing, hell im running one, just dont want to get anyones hopes up to think that by slapping on a tune without doing anything else they are going to make a powerhouse burnout machine.
    Needless to say, OP, hit up OTT/JustDSM for a tune, hes been the most active in the 2nd gen taco tuning community.
    seedy_tea, JustDSM and TnShooter like this.
  11. Feb 22, 2023 at 8:43 AM
    BlessdApparel1
    Oceanside
    This Weekend I will be getting a custom Tune by @moddedbyphil On instagram and Im excited to see how it performs and the difference over stock. After talking to Phil, I was given some great points and really what to expect. I will keep you updated.
  12. Feb 24, 2023 at 3:15 PM
    Skawdee
    Skawdee SKOL Vikings!
    Star Valley, Wyoming
    2009 Tacoma TRD-Offroad, 6-spd Man.
    Old Man Emu 2.5” Full Suspension Lift w/ Wheeler's Off-Road Progressive Leaf Pack JBA Upper Control Arms Moog Lower Control Arms Victory4x4 Strike Front Bumper w/ Grill Tubing Morimoto XB Headlights Baja Designs Squadron Sport Amber Fog LED’s Baja Designs 20” White LED Light Bar Over-sized BFG All-Terrain Tires K&N Stock Replacement Air Filter Pioneer AVIC-W8400 Head Unit Apple TV Wireless Phone Charging Pad Bed rail mounting with ax, shovel, MaxTrax Bed Extender
    What are your thoughts on getting the Overland tailor torque tuning (OTT) for my 2009 Tacoma that’s an MT 6-speed with 165k miles? Do they make a good difference in drivability? I have a K&N air filter in the stock box, the OME 2.5” lift and 265-75-16 tires. I live at 6200’ elevation and spend a lot of time hunting, forest road low-speed cruising, light off-roading, sometimes pull a small 14' aluminum boat, and there’s tons of snow half the year. Does it affect MPG’s? Thanks for any insight as I’m debating getting it tomorrow from a guy down in Blackfoot, Idaho according to the service map on the site! Thanks.
    Scott
    Jackson, Wy
