Let's see some 18 inch wheels
Discussion in 'Wheels & Tires' started by bravosvo, Feb 10, 2010.
  1. Feb 10, 2010 at 8:55 AM
    bravosvo
    bravosvo [OP] Active Member
    Can we see some 18in wheels pics on your Taco?
  2. Feb 10, 2010 at 9:05 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    18x9" BBS RW's w/ 265/65/18's.
    Mikenewgun87 likes this.
  3. Feb 10, 2010 at 9:14 AM
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    18x8 MB Gunner6 285/60/18 Nitto TerraGrapplers
    18x9 Helo Maxx6 285/60 NTG
  4. Feb 10, 2010 at 9:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Feb 10, 2010 at 11:45 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Very nice.
  6. Feb 10, 2010 at 11:50 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  7. Feb 10, 2010 at 12:45 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
  8. Feb 10, 2010 at 12:52 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Can you put 18" wheels on a Tacoma without lifting it? If so, can you use the same tire aspect ratio as the OEM tire (xxx/75)?
  9. Feb 10, 2010 at 12:57 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    XRunner Rims 18".
  10. Feb 10, 2010 at 1:00 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    18x9"s with 285/65/18"s running on NDG's.
  11. Feb 10, 2010 at 1:02 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Man, those are low profile tires. Aren't you worried about potholes? What is the aspect ratio on those?
  12. Feb 10, 2010 at 2:18 PM
    TexasTacoma37
    Yes, my truck (post #2) is on 18's with no lift.
    The OEM ratio would be 265/60/18. That's equivalent to 265/70/16 or 245/75/16.
  13. Feb 10, 2010 at 2:45 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Excellent, thanks! your truck looks good Keith!
  14. Feb 10, 2010 at 2:48 PM
    TexasTacoma37
    Thank you. Please note that I have 265/65/18's though, which are one inch larger diameter than OEM. They are the same as 265/75/16's, which are very popular on here.
  15. Feb 10, 2010 at 2:51 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Understood......very good, as I really don't care for the "low profile" look. I like a sidewall that can provide some cushion AND support....it gives a much better ride IMHO.
  16. Feb 10, 2010 at 7:25 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    With custom center caps.
  17. Feb 11, 2010 at 8:01 AM
    Biff
    Biff What could go wrong?
    Winnipeg
    07 SR5 Doublecab
    Bilstein 5100's all around, fronts set to 1.75, 18" Method Race Wheels, 285/60/18 Cooper Zeon LTZ
    .....sorry for the bump - i am in the market for 18" wheels so this is a good thread.
  18. Oct 25, 2012 at 6:30 PM
    SCTacoma1
    SCTacoma1 Member
    South Carolina
    2013 Tacoma TRD Off Road Pkg
    Just so I understand, 265/65/18 tires will fit without a lift kit and without rubbing? Im new to buying aftermarket wheels and tires etc.
  19. Oct 25, 2012 at 7:03 PM
    MarkEmarK
    MarkEmarK Well-Known Member
    Mark
    NorSoCal808
    2012 MGM DCLB 4X4
    Broke Stock
    It should fit. I have that size on the stock TRD Sport upgrade rims.
  20. Oct 26, 2012 at 5:43 AM
    TexasTacoma37
    Yes
    The stock 18" tires are 265/60/18 I believe.
