Let's see some lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lelandt, Mar 18, 2015.
  1. Nov 29, 2017 at 4:32 PM
    #161
    westpalmdoc
    westpalmdoc Well-Known Member
    andrew
    Ford Roush Raptor 2018
    none, its a Raptor
    Spyder smoked headlights. Rough Country 50 in curved bar
    Coolerman likes this.
  2. Nov 29, 2017 at 5:33 PM
    #162
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Mine
    Lelandt[OP] and zh137dz like this.
  3. Nov 29, 2017 at 5:46 PM
    #163
    Hummer911
    Hummer911 Well-Known Member
    Rick
    So. Cal
    2014 RC 4X4 MGM Auto
    BDS 6" lift, Toyo tires on Method wheels
    Retrofit headlights and Caliraised 30" LED light bar.
  4. Nov 30, 2017 at 5:17 AM
    #164
    thirsty3
    thirsty3 Active Member
    Sam
    Maine
    2013 TRD Sport DCSB
    5100/887's, LR UCA's, HD Dakars, SCS Ray-10s w/ Falken 285/70-17
    30" light bar from the retrofit source's closeouts section, paid $40. I was skeptical due to the price, but damn is it bright.
    Lelandt[OP], o0oSHADOWo0o and zh137dz like this.
  5. Nov 30, 2017 at 5:35 AM
    #165
    Hilife96768
    Hilife96768 New Member
    05 trd sport dbl cab
    You got a link for the bar n mounts?
  6. Nov 30, 2017 at 7:51 AM
    #166
    zh137dz
    zh137dz Well-Known Member
    Nashville, TN
    2012 Tacoma Prerunner TRD Sport
    too many lights
    Looks great! I kind of miss my stealth look of the lightbar down there but it has side-floods with a center spotlight and wanted to get the full effect. If the lower valence didn't cost so much I might have gone back after all the cutting.
    thirsty3[QUOTED] likes this.
  7. Nov 30, 2017 at 8:56 AM
    #167
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
  8. Nov 30, 2017 at 9:08 AM
    #168
    Kcross33
    Kcross33 Well-Known Member
    Kade
    Fresno, Ca
    2006 TRD Off Road prerunner
  9. Nov 9, 2018 at 3:55 AM
    #169
    Lelandt
    Lelandt [OP] Well-Known Member
    Tavish
    Maine
    08 TRD OR
    bully bull bar, halo/angle eye headlights, 20" cree led light bar mounted on bull bar. 42" radius light bar from extreme LEDs 2 led pods, Spare tire mount on bed
    Removed my roof lights and bullbar. Still have the 20” light bar from the bullbar that I would like to put behind the bumper/grill. What have you guys used to mount them
  10. Nov 9, 2018 at 7:34 AM
    #170
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C’d DCLB TRD SPORT
  11. Nov 9, 2018 at 7:39 AM
    #171
    ChadsPride
    Sponsored by TacomaWorld.com
    Ditch - Rigid side shooters w/ Amber covers
    Street fogs - Rigid SAE pods w/clear covers (on OEM harness)
    Off-road fogs - Rigid flood pods w/ Amber covers (wiring this weekend)
    Light bar - Rigid single row 20" hypersot/flood combo (wiring this weekend)
    Rear - Rigid diffused pods (wiring this weekend)
  12. Nov 9, 2018 at 7:51 AM
    #172
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Should probably update my first post here from 3 years ago. Light setup and truck have come a long way!
    40" Single row Heretic
    20" Amazon Double row with 3 layers of clear amber vinyl from Amazon.
    2x2 Amazon LED pods
    Black oak LED Sasquatch/UFO landing lights
    Rigid 2x1 combo reverse/tailgater lights :luvya:
    Rock Lights
    Bed lights
    Lelandt[OP] and ChadsPride like this.
  13. Nov 9, 2018 at 8:50 AM
    #173
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Raptor lights and/or 20in bar behind grille. Side shooters ditch lights.
    Bed lights
    Rigid Chase for when the RTT is mounted
  14. Nov 9, 2018 at 3:05 PM
    #174
    SammiStriker
    SammiStriker New Member
    Kyle
    2005 Double-Cab / Desert Sand Mica
    Rough Country Leveling Kit Randy Ellis Lightbar
    Too bright for a good phone picture with all of them on. :p
  15. Nov 11, 2018 at 7:35 AM
    #175
    ChadsPride
